Question about Car Audio & Video
I HAVE A AMP AND SUB HOOKED UP 2 MY KENWOOD STERO, HOW CAN I INSTALL IT THE RIGHT WAY SO THAT IT WLL TURN OFF WITH THE CAR?????
  • 58 Answers
If your radio shuts off with the key and you use the power ant. or the amp turn on wire for your amp when your radio shuts off so will your amps. If your radio is wired constant hot you need to change the red wire on your radio to a key hot.
Posted on Aug 20, 2010
How to install kenwood 729s withno rca outlet on radio
You can run the speaker wires to the speaker level input on the amp or i believe you can run another set of speaker wires spliced into the existing wires in parallel to the speaker level input along with the speakers that are already hooked up if you are using the amp for a sub or other speakers that you have added to the existing system.
Apr 14, 2014 | Kenwood KAC-729S Car Audio Amplifier
Kenwoodxw1000f shut off after 10 sec
the problem sounds like your new sub is drawing to much power and your amp can not handle it. bridging the amp is a good way to get the full power out of your amp. But it isnt always suggested, my solution is to get a bigger amp. I install stereo systems for a living, and i tell my customers that it is smart to get an amp about 100 more watts then the rms rating of your subwoofer.
Feb 13, 2010 | Kenwood eXcelon KFC-XW1000F Car Subwoofer
Have 600w amp 2 10's and they aint even bumpin, DO I NEED TO BRIDGE IT
No, that'll use two channels to power one sub. First, is the gain turned up? There's a knob on the amp to turn it up. If the gain is already up, and if the amp is two-ohm stable, then wire the subs in parallel. I'm assuming the subs are each hooked up to their own individual channel. Swap the two negative wires at the amp, so sub 1 is hooked up to channel 1 positive and channel 2 negative, and vice versa for the other sub. That'll dramatically increase the output. Again, make sure the amp documentation says it is 2-ohm stable, or you'll damage your system.
Dec 24, 2009 | Kenwood KAC-729S Car Audio Amplifier
I have a Kenwood KFC-W3514DVC and its hooked up to a Valor Multimedia VPA402 500 watt 2 channel amplifier. If i want to optomize my system the cheapest way should i buy another subwoofer or should i buy a...
find the rms rating of the sub and compare it to the amp.if the rms of the amp is higher than the sub you have enough power to push the sub.if its lower look at the rms of the amp if it can be bridged.you would like to see the rms matched to the sub or subs if you have enough power.
Sep 06, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
Deck, Sub and Amp Problems
check for any loose connections at the fuse block or a loose fuse
using an ohm meter would help
check the harness on the back of the radio for loose connection
bad igntion switch, again an ohm meter would help !
what type vehicle ?
Jan 13, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp light turning off and on
if you see that happen you might need to your i c sound chip or your trasistor change then and check
Dec 11, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
Kenwwood amp will not turn on
u need a capacitor and a new battery. the capacitor stores reserve power to power the sub and ur old battery isn't producing enough juice for the amp so get a new one
Jan 09, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
