Question about Whirlpool LGB6300 Gas Dryer
Whirlpool Gas Dryer Model # LGR7646JQ0. Bought it used, warranty useless since the shop I got it from went out of business. Everything works fine. The drum turns, the timer works but the thing doesn't heat up. I have already checked the gas supply line and the dryer is getting gas. I cleaned out the vent and the lint filter and still no heat. What can I do to fix this?
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Your power for the burner assy goes on a series circuit from the timer to the high-limit thermostat to the operating thermostat to the thermal fuse to the gas burner assy, thru the motor centrifugal switch to the door switch. EACH of these must be functioning for the burner to light.
This manual will help with some of the how to do it as far as component access, removal and replacement of parts.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
Also this link has loads of information on what to check.
http://fixitnow.com/wp/2006/09/19/how-to-check-the-burner-components-in-a-gas-dryer/
The 3 most common failures are
Igniter:
Gas Valve
High Limit Thermostat
Compnents : http://fixitnow.com/appliantology/gasdryer.htm
Note the LINKS!
Here is a 9 min video that pretty much covers everything you need to check: http://www.howcast.com/videos/371390-How-To-Troubleshoot-a-Gas-Dryer-That-Wont-Heat
Thanks fo choosing FixYa.
Kelly
The
Posted on Aug 20, 2010
  • Whirlpool Master
  • 2,287 Answers
On the left side of dryer you'll see a plastic cap,pop it off,start the dryer and look inside the hole and see if the ignitor is glowing,if it doesn't you could have a bad sensor or the ignitor is bad,unplug the dryer and with a meter check the sensor and the ignitor to see what's bad.if it does glow and then goes out without lighting you could have bad gas coils or a bad gas valve,let me know what you find
I have a whirlpool dryer that won't start. I am renting and the owner doesn't know the model number. The power to the house went out and everything came back on except the dryer. I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 06, 2011 | Whirlpool LGV4634JQ Gas Dryer
Ive changed the ignitor, sensor, thermostat, fuse-thrml, and thermostat-fix.. my dryer still is only heating for only 5 min then goes cold. what can i do? model: LGR7646JQ0
This is usually the dryer coils have failed. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a video on replacing the dryer coils.
Nov 11, 2010 | Whirlpool LGR7648KQ Dryer
I have a Whirlpool LGR7646JQ0 Gas dryer. It wasn't heating. I took it apart and used a meter to check the list of things in a video linked to me here. Turned out to be the coils. Replaced those and the...
Lack of airflow can cause the unit to overheat and shutdown. Check all the vent pipes for obstruction. IT could also be the high limit or the thermostat that is bad.
Apr 03, 2017 | Whirlpool Dryers
Working fine this morn went to use again wont start
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 19, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirlpool LGR7646JQ0 gas dryer..the burner shuts off?
Sounds like you have a bad warp switch. Also could have a gas valve going bad.
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
DRYER NOT WORKING. MODEL #LGR7646JQ0, SER #MK4629649, PURCHASED 11/18/00. PROBLEM: DRYER COMES ON HOT AND QUICKLY (ABOUT 5 MINUTES TURNS COLD) IF I WAIT ABOUT 2 HOURS AND TURN IT BACK ON IT REPEATS HOT...
http://www.searspartsdirect.com/partsdirect/retrieveModelAction!retrieve.action?modelNumber=LGR7646JQ0
This should show you a parts break down for the unit. You can also find a schematic in the console (usually about 6 1/4" screws from the back of the console). As far as your problem, overheating could be causing it. Run the unit without the vent attached and see if the problem persists. If the unit keeps running, you'll know you have a venting problem. If the problem persists, I would usually replace the gas valves (usually one goes bad and won't hold open). These would be availible from a local appliance parts store.
Jul 08, 2008 | Whirlpool Dryers
Burning smell
We had the same problem. After we used it a few times, the smell went away.
Jul 06, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryer is running but it's not hot
If the electronic start is not working, it may need to be replaced. Call an appliance parts store and ask some specific questions to them about how you can test that component and if they carry a replacement for your specific make and model. Good Luck!
Jul 05, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LGB6300 Gas Dryer Logo
653 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
