Question about Amcor A12000E Nanomax Portable Air Conditioner
I can not get the unit to move from 77 degrees
  • 107 Answers
The thermostat wont move below 77 ?
Posted on Aug 20, 2010
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
Thermistor resistance should be 10K@ 77 Far..Mine is showing 13.5k @ 70 far. is that out of tolerance?
Without a chart in front of me, I can't tell. But you can download a thermistor coefficient chart from Tranes site or any of many different manufacturers. But why don't you slowly elevate the temperature of the thermistor to 77 degrees with a thermocouple style sensor taped to it and check it specifically AT 77 degrees ? Use a hair dryer on low and wave it a couple feet away to slowly bring it up to temp while monitoring the display on your digital DVOM..
A 10,000 ohm at 77 degree thermistor is very much a standard thermistor throughout the HVAC industry. I have charts at home, but at present am not near there.
Dec 06, 2014 | Dryers
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
I've just moved into a home with an existing Armstrong Concept 10 A/C unit that's at least 15 years old. When I left for a 2-week vacation, the unit was working great. I set the thermostat to 77 to save...
Hello 93 The compressor caused the breaker to trip.A weak capasitor or burnt wire is a common cause.It sounds like the compressor is NOT on even though the fan is.It may need a new wire or maybe a HARD START kit to help restore operation.Call for help.HS kits are not expensive.NO damage results from leaving it on, the problem would have happened anyway even if you went on vacation or not.The curcit breaker stopped it.Its worth fixing.
Aug 30, 2010 | Heating & Cooling
I have the Haier HWR08XC7 (8000 BTU) and my problem is that I have the thermostat set at 70 degrees, but it stays at 77 or 78 degrees... What could be the problem as the unit is 2 yrs old??
Hi!!
Check your owners manual, probably have unit set at automatic comfort level or some energy saver mode. It should say something on the remote about it.
Good Day!! Don't forget to rate this post!!
Aug 13, 2010 | Haier Heating & Cooling
My ac unit will not go below 77 degrees. It quit working about 1.5 weeks ago, and I had a service technican come and look at it. He replaced the capacitor and the unit started back up and would cool to...
Hi, It sounds to me like you have covered all of the basis. The evaporator coil should be clean if you keep your filter clean and the condensation is showing that it is cooling properly. Normally, when the temperature increases outside, you will loose as much as 35% of your units efficency as it it working very hard. 77 degrees is very good temperature if the outdoor temperature is in the triple digits or a little less. It may be that your thermostat is off just a little also. If you clean your coils and keep it up like he said, that is great! I wish more people would do this. You should have a 18 to 25 degree temperature difference between the supply air from you vents and the return air at your filter. Example, if your supply air is 56 degrees, and the return air is 76 degrees, a 20 degree difference or TD, that is excellent. You can check this with a thermometer. I live in Northern Ca and it gets up to 116 degrees here in Redding!! We are lucky to have it 80 degrees in our home, no kidding!!. If you are unhappy, call this tech about it and see what he says. Your indoor coil is fine if you have no ice and I know you keep your filter clean. If you lost a capacitor again, you would have no cooling. Like I say, keep a eye on it, it could be the stat not accurate. Check the supply at the vents and filter to see what you have. If its lower then 18 degrees or higher then 25, you have a problem. If you are in the triple digits, this will cause this. I wish you the best and keep up the good work on that unit! That' great! Please keep me posted and please be kind when rating me as I know you will. Let me know the out come.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 05, 2010 | Heating & Cooling
'77 Chevy C-10. Spark plug gap and timing degrees
8 degrees BTDC (6 in calif) spark plug gap 0.45"
Sep 11, 2009 | 1983 Chevrolet K1500
Cooling Problems
Your filter is clogged. Not the one at the bottom of the unit.The one above the unit. It is like a raditor coils, kind of a bear to get to. We have cats and dogs the filter gets most of the hair but not all.Usualy about 6 bolts to take out.The proublem will be at the bottom of the top filter.
May 09, 2008 | Honeywell Electronic Programmable...
Amcor A12000E Nanomax Portable Air Conditioner Logo
151 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
