Question about HP Computers & Internet
Where can I buy Aspen-GL8E motherboard - HP Computers & Internet
Ms-7548 mobo no post beep and screen goes black after startup
this sounds like you have picked up a virus there are a few that will do this, you will need to reformat the hard drive. or use a backup disc if you have one made to install on computer. make sure you only go into computer in safe mode and use virus software to try and remove it. this virus attacks the startup file on the hard drive, and the reg files allocation. hope this helps failing this the hard drive has wiped its self when it has not shut down properly.
May 09, 2014 | HP MS-7548 System Board Motherboard...
Tip
Why choose HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E??
Things to be considered in choosing HP Pegatron M2N78-LA ASUS OEM Violet6-GL8E
1. Processor and Memory upgraded
3. I/O Ports and Network
5. Clearing BIOS password
For details you can visit web site www.hpparts.us
on Apr 02, 2014 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Download manual for hp pn 5188 7687
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle GL8E motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle2 GL8E motherboard,
http://www.algogo.com/store/products/ECS-HP-MCP61PM%252dHM-Nettle2%252dGL8E-6150SE-AM2-Motherboard.html
The ECS MCP61PM-HM motherboard otherwise known as the HP Nettle3 GL8E motherboard,
http://www.amazon.com/ECS-MCP61PM-HM-Nettle3-GL8E-6150SE-Motherboard/dp/B0045X6N1S
Which one is it?
Oct 24, 2011 | Computers & Internet
Can u plz tell me from where i get compaq asterope driver
Use these links:
http://www.downloadnotebookdriver.com/article/compaq-motherboard-asterope-driver-gl8e.html
http://www.driverstt.com/hp-drivers/hp-compaq-motherboard-asterope-3-gl8e
http://www.ascendtech.us/itemdesc.asp?ic=MB4HPECSRC410M
Apr 12, 2011 | Computers & Internet
I Have a HP Pavilion a6110in PC. Procesor AMD Athlon 64x2 3600+. Its motherboard have problem.I want to buy a motherboard for it. Request suitable motherboard and price at Visakhapatnam (India)
i believe what you need is this p/n CG781-69002, Motherboard (system board) Narra2 GL8E - This is a micro-ATX form factor, Asus M2N68-LA, Socket AM2 (Athlon 64, Athlon 64 X2 with Dual-Core and Sempron) CPU supported
is your computer p/n GG781AA ?
Oct 19, 2010 | HP Computers & Internet
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
Motherboard
  • Motherboard manufacturer's name: ECS RC410-M
  • HP/Compaq name: Asterope-GL8E
Aug 19, 2008 | Compaq (261671-001) Motherboard
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
