Question about Xantrex Technology DR2412 Inverter / Charger
We are in Haiti, our 13K generator broke down. Someone lend us a generator and we plugged our inverter to it to charge our batteries. It didn't work and since, even when plugged to yet another generator we can't get the inverter to switch to charge and it emits sparks inside the inverter, any idea what went wrong?
  • 12,061 Answers
Hi, well you see this happened because the "Load" on the Inverter was more than it could handle. You see the Inverter senses the resistance of the batteries to determine how flat they are and how much current to put into the batteries, if anything else is connected to said batteries, that will simply muck up the sensing,and as has happened in your case destroyed the inverter.
I have serviced many inverters and the most likely failure that would emit sparks etc is failed output semiconductors.
One cannot really use an inverter to charge the batteries, like you did, UNLESS the batteries were completely isolated from the Generators wiring, and even then, your inverter, still may not have enough power to do this. As this is NOT what it was designed for.
Really an inverter is used to step up the Voltage from 12/24 Volts DC, batteries to 120/230 V AC.
Now again, one could use it, to then have a Battery Charger plugged into that, and use the output from the battery charger to charge some "Other" batteries, but that seems a bit roundabout.
Yes the Inverter will charge it's OWN batteries, BUT ONLY if that is the ONLY thing connected to the inverter.
Posted on Aug 20, 2010
Can't find the transfer switch, and could it go bad. Shore power and generator power works to the main panel box, but won't charge coach batteries
although it is possible to do separately most times the transfer switch is internal to the inverter , and the fact you mention that inverter is not charging batteries tells me your fault lay in the inverter all or part of it is not working , look at it carefully these have sometimes two reset breakers on there cases
Jun 01, 2015 | Inverter Electronics - Others
The electric start down not work
At risk of stating the obvious... Is the battery charged and/or connected? Does it at least click like it wants to start?
Jul 28, 2014 | Honda EU3000iS Inverter Generator
My onan emerald 1 genset is not transfering charge to the battery
Assuming your generator has the battery charger option?
Measure the battery voltage at the battery lead in the generator, without the unit running, or the motorhome ignition on. It should read approx 12V after the unit has been sitting a while. Then start the generator, it should rise to approx 13.8 with a good battery. If it does not then the stator windings and charge rectifier in the generator should be checked. If the voltage is 13.8 approx with the generator then you problem lies further upstream, and possibly with an isolation solenoid. If you generator does not have a battery charge winding/option then charging comes from the line voltage via a motorhomes inverter, check the inverter.
Sep 08, 2012 | Onan RV QG, 2500W GenSet, LP Gas
I'm dumb. Can I hook an inverater to my generator and produce more enegry than my generator produces???
Please understand that the generator produces power from fuel with an engine wheras the invertor is one which genrerates power from a stored battery using the principle of frequency switching a DC source to induct and produce AC.
Now you can have an uninterupted power supply setting with the invertor backed up by the generator so that when the battery voltage goes down you can start and charge the invertor and also supply the extra energy .
the ratings of both must also be considered.
Sep 25, 2010 | Electronics - Others
I recently bought a used 2004 Fleetwood Discovery 39L with a Xantrex Freedom 458 system in it. The system worked (sort of) for the first few months I owned it, but now fails to charge the house batteries....
It sounds as if your inverter has failed altogether. This failure could also be caused by power management having issues.
So far, I know that you have a 2004 Fleetwood Discovery 39L. If memory serves, this is a *30AMP* chassis, with 2 air conditioners, using an intellitec power management panel located above the driver position. If I am incorrect, please advise.
Aug 18, 2010 | Xantrex Technology Xantrex Freedom Xmic...
Helloi bought a new TR2424-230-50 inverter and 2 X 12V batteries connected. When charging with my 5KVA generator the generator frequency is very unstable and the amps (a/c) drawn is upto 10A. Is there a...
Frequency is a function of generator RPM. Slower the engine, lower the frequency. Faster the engine, higher then frequency.
Look at your generator first, it should be able to maintain this load without problems - check your governor.
You can try plugging in a lamp directly into the generator so that it won't see a pure inductive (input to inverter) load, but will also see the resistive load from the lamp.
Power Draw of 10Amps is going to be what it is, unless you change the AMP Hour capacity of your battery bank that is connected. Be careful though, as this will not only reduce the charging current (and amount of load present on the generator), but it may also affect how the inverter operates with heavy loads, and may cause the charging profile to go into bulk and float modes prematurely.
Are you feeding your generator into the inverter via the transfer switch, or are you plugging the coach power cord into the generator? The former would force all the AC loads to be switched by the inverter, the latter allows all ac loads to be powered, even those that you may not know about / realize (water heater loads are a big one) and eat up generator capacity.
Jun 21, 2010 | Xantrex Technology Trace Series Inverter /...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
When my batteries run low on power the generator starts up. Most of the time the system works perfectly, but lately the inverter will click and keep clicking and the batteries will not charge, then the...
please check the voltage your generator is supplying to the to the inverter because a high voltage and frequency can make the relays in the inverter to make clicking sounds,and also do not allow your inverter batteries to run completely low before you charge it
Jan 06, 2010 | Xantrex Technology Trace Series Inverter /...
Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Jul 15, 2009 | Xantrex Technology Heart Freedom 30...
Xantrex Technology DR2412 Inverter / Charger Logo
100 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
