Question about Magellan RoadMate 2200T GPS Receiver
The GPS won't charge
The Magellan 2200T GPS Just stopped charging. I tried the DC and AC charger but nothing happened.
    Problem Solver:
  • 8 Answers
I answered this on another thread, I removed the back cover, 6 screws, and pulled the battery connector from the board, waited a minute or two, then reconnected. another poster said also that the connector for the power may have gotten loose, you can tighten that also but be careful. I did not have to do this, only the battery. Do NOT do this with a power cord plugged in, to be safe.
Posted on May 18, 2008
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
Cord will not light up or charge magellan
if the light does not com one on the car charger, try another charger if you have one, or a home charge if you have one of those...this model also has a common problem if you have a good charger.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Feb 07, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
Make sure
You can
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
Magellan 4040 won't turn on or charge.
Make sure
You can
Jan 12, 2010 | Magellan Maestro 3250 GPS
I just bought a good used Magellan 2200t for my son wont turn on
Make sure
You can
buy the port or get it repaired, here
Jan 04, 2010 | Magellan RoadMate 2200T GPS Receiver
Magellan maestro 3100 will not hold a charge
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Dec 02, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 405 won't take a charge from the car
hi tc76,
plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
now press and hold the power button for up to ten seconds until it starts. if that fails
this is a very common problem for the models listed below.
you can get help to repaired it, here
bill
Nov 29, 2009 | GPS
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
Nov 09, 2009 | Magellan Maestro 4000 GPS
My gps needs charging but the charger isn't working, the connection from the charger to the gps is loose.
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040 4050and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port.
Oct 12, 2009 | Magellan RoadMate 2200T GPS Receiver
Magellan Roadmate 2200T -dark screen
its probably not charging...very common problem with this and many others.
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
Oct 09, 2009 | GPS
Magellan RoadMate 2200T GPS Receiver Logo
70 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
