Question about Maytag Dishwashers
Plastic coating has worn off in several places on top rack. Leaves rust spots on plates.
  • Maytag Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 20, 2010
  • kenaune123 Aug 23, 2010
    Have tried that, it seems that the rack is no longer available, and there is no suitable replacement for it.
  • D. Floyd Kolb
    D. Floyd Kolb Aug 23, 2010
    In that case there is another, but more difficult way to do it and it won't look as pretty. But is functional.....
    http://www.plastidip.com/
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Tip
How to Stop the dishwasher from breaking my glasses
This shelving costs $16 plus $20 for powder coating.
Very easy to assemble taking about 2 hours.
It will stabilize your dishwasher trays so glasses wont fall over. Therefore wont break.
Buy 2 large Baking racks with 1 cm holes from Myers for $8 each.
Use your Angle Grinder to cut to size, making sure the cross wires running from left to right are on top of the long runs. This is because your glasses would slip all the way to the front, if you mounted the racks up the wrong way.
Basically I cut off only one side of the rack, using the cutoff piece for the middle hole.
Next flatten those legs that wont let the rack sit flat down, by using your vice and hammer.
See the diagram below how wide the framing supports wires are apart, that is why nothing stands up on them.
You may have to discard other supplied movable racking.
But the inserted racks, with a hole cut in the middle rack to allow a raised support wire some space, are very stable.
Now after cutting hammering and bending the racks loose some coating and will rust with little rust marks appearing on the edges of all your crockery and cups.
Therefore you will need to powder coat them any colour for years of protection.
Just find a powder coater in the yellow pages and give him the cutout racks.
To save money I told him to coat my Black racks to any colour in his machine, which turned out white.
Note the glass which now stands up stable and straight.
on Feb 06, 2015 | Dishwashers
Fit top box rack on honda vfr800
you only use four make sure you put the spacers ond washers in the right place rubber washer plastic washersto the metal plate both sides then rubber washers then then metal washer then nut
Oct 09, 2009 | Honda VFR 800 Motorcycles
Upper and lower racks of Beaumark dishwasher purchased in mid-1990s (model and serial number available) need replacing. Coating on metal racks has worn away and resulting rust is getting on dishes....
check with a local auto body paint shop. they might be able to sand blast them and powder paint them, better than new .or perhaps that stuff I see on TV FLeX COAT spray or brush on rubber coating
Dec 15, 2017 | Dishwashers
There are some worn, rusty spots on the lower basket of our Magtag. These are small spots where the plates rest against the tines. Are there any products to repair the plastic finish?
You can buy tine caps and repair goop at an appliance repair shop, however once rust has penetrated it is generally hard to stop
Sep 07, 2009 | Dishwashers
Kitchen Aid SS Dishwasher KUD102CRBS1 - Top Rack has 3 rusty spot
Looks like you can get the upper rack for about half that, direct from Sears-
Dishwasher Dishrack Upper Part Number 8539234 Sears PartsDirect
Still kinda pricey if you only have a few bad spots.
There is special touchup coating (never tried it myself, but looks like it gets good reviews, and the price is right)
Amazon com Rerack Dishwasher Rack Repair White 630076 Home Improvement
Or prong covers if you just have rust or damage on the tips (I've used ones like these, the long ones stay on good)
Amazon com Home Dishwasher Prong Caps Set of 20 Kitchen Dining
Oct 20, 2017 | KitchenAid Dishwashers
My viking dishwasher does not rinse the soap scum off the dishes
Maybe . . . remove the lower rack and invert it. Look for cracked or missing plastic coating, exposed, rusted & possibly "swollen" inner steel rod/wire. If found, remove the upper rack and look for more of the same. What you think is "soap scum" is probably rust and other iron compounds leached by the dish soap out of the rusted steel onto the dishes and the dishwasher interior. The following worked for me . . .
To clean the interior (with both racks removed), set to "No Heat" dry, then "Pot & Pan" wash and allow to fill. Open door, dump in a bottle of "Lime A-Way", close & latch door and allow to complete cycle. This should remove most rust and iron-sulphate deposits from interior. If not, scrub them with Lime A-Way and a ScotchBrite pad, then cycle again.
Racks must be replaced (Viking are very expensive, Asko, Bosch, or other lower racks may fit: check your neighbors' racks for fit), upper rack must be Viking unless you can exact-match the Asko or Bosch equivalent.
Possible fix: remove the loose plastic coating and flaking rust with a knife, ruff plastic coating with ScotchBrite, clean with rubbing alcohol, then treat metal/rust with "rust converter" (hardware or home imp store), wash with soapy water, rinse, then clean with rubbing alcohol, dry fully, coat with "high temp" (orange or yellow) silicone sealant (auto part store), covering exposed metal and a half inch or so over the plastic coating. Let set for a day or two.
A trip through the dishwasher for all your stained stainless, glasses and non-metallic coated or non-metallic decorated dishes with Lime A-Way as above (on new or "rebuilt" racks) should get the metallic scum and rust off them.
Apr 18, 2009 | Viking 24 in. Professional Series VUD141...
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Racks rusting and falling apart
Do not know about a recal. But you can buy the racks at your local Sears service senter or on line at www.Sears.com
Dec 17, 2008 | Kenmore 15529 Built-in Dishwasher
RUST SPOTS
My 10 year old Kenmore (Whirlpool) top load washer is rusting under the top cover. The entire cover from the bleach dispenser all around is rusted under the lid. Periodically, rust dislodges into the tub and stains whites. You would have to treat the rust under the lid. I decided to try, using "Rust-mort" rust treatment on a rag. The rust would all have to be wetted with the rustmort after some scrubbing with a scuff pad. I have not attempted this yet.
I went to OSH and checked lids on new top load washers. The lip on the cheaper models was not properly coated with paint, and I could feel the rough partially exposed metal, which would rust. The more expensive models had a smooth well coated lip on the underside of the cover. Hope this helps.
Oct 22, 2008 | Washing Machines
Dishwashers Logo
119 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
