Question about Nokia 1600 Cellular Phone
Nokia 1600 problem: 4 ---> 741
I have a problem when i am pressing 4 then it shows 741 and when i press 5 then it shows 852 and when i press 6 it shows 963 ...... how i can i solve this problem in nokia 1600 please help me out
What is the history of your phone, i am a cellphone technician.
Posted on May 08, 2008
My Toshiba e-Studio 2506 shows the error "Call for Service C413", what can I do to solve this problem? Help me please!
perform the following:
1. Turn ON the power while [0] and [8] are pressed
simultaneously.
2. Key in "2002", then press [START].
3. Change the current status counter value "3" or "4" to "0",
then press [OK] (to cancel [C413 / C414]).
4. Turn the power OFF and then back ON. Make sure that the
equipment enters the normal ready state.
Sep 27, 2016 | Toshiba Office Equipment & Supplies
Ti 5006II frozen
I had the same problem. Solved it by pressing the D/# key (just below 5/4 key) and then pressed the P/NP key (not sure if I pressed them at the same time).
Also pressed the D/# key and 5/4 key.
In my case, the screen showed an 'E' lower left of screen, and the 'Print' and '5/4' at the top of the screen.
Hope this helps.
Mar 18, 2014 | Texas Instruments TI-5006 II Calculator
Error code 042-326
Hold down 0 (zero) for 5 seconds and press start (green) button
enter 6789, confirm
press log in/log out button or the key button
press systems settings, common settings, maintenance, NVM read/ write
enter nvm 741-105 and change it to 0 (zero)
(copied from forum copytechnet, user TechMate)
Oct 13, 2013 | Office Equipment & Supplies
My printer show error e07 how to solve
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
4 times Green Waste ink counter reset
Jun 01, 2012 | Office Equipment & Supplies
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
Unlock a Philips portable DVD Player Pet 741/37
It worked for my Philips PET741/37:
1. Power ON the DVD player without a DISC inside
2. Press the skip keys in this order (the keys are under the "disc menu" and "stop"): right, left, right, left, right, right, left (YOU DON'T HAVE TO GO TO SETUP MENU, just do this in the "blue screen".
3. It will show a menu with region, now use the arrow keys to select "region" and change to "test 0" (all regions).
4. Press OK to confirm. Enjoy
Silmara
May 15, 2010 | Philips PET724 Portable DVD Player
Indicate h 4
When this copier power abnormal or heater abnormal then show H4
Solve: # interrupt C interrupt press 14 press start key if it is power abnormal then solve if you not solve you must be change Heater Lamp.
Mar 31, 2010 | Sharp AR-5320 Black and White Copier
Can it solve 8^x=4 ???
You can use algebra to solve it.
Use the fact that 4 =2^2 and 8=2^3 and substitute in the equation
(2^3)^x =2^(3*x)
Then 2^(3*x)=2^2
By equating the exponents
3x=2 and x=2/3
Using the solve( function
With the calculator physical keys between square brackets, and the SHIFTed or ALPHA keys between parentheses, type in the following
8 [^ ] [ALPHA] [ ) ] (X) [ALPHA][CALC] ( =) 4 [SHIFT][CALC] (SOLVE)
Once the foregoing command entered press [=]
Display shows Solve for X on top line and probably 0.000 on bottom line.
Press [.] 5 to give 0.5 as a guess for the value of x
After a moment the calculator returns with the solution.
The display shows three lines
1st Line: 8[^] X =4
2nd Line: X= 0.66666666
3rd Line : L-R =0.
Your solution is 0.6666666. In fact the exact solution is 2/3.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 03, 2009 | Casio FX-115ES Scientific Calculator
My printer show error e28, help solve it, please
E28 = Ink cartridge temperature rise error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
5) Unplug cable power.
Aug 04, 2009 | Canon Office Equipment & Supplies
Laptop Keyboard problem
Press and hold the shift key then press the NumLock key.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 16, 2009 | IBM ThinkPad R51 Notebook
Nokia 1600 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
