Question about Dell Precision T5500 Computer Workstation PC Desktop
My computer beeps when external drive is plugged into USB
  • 21 Answers
That's normal, the node is recognizing the external drive. If it's during boot up it will look for a bootable partition on the external drive if its given 1st priority in the cmos.
Posted on Nov 25, 2014
Beeping external hard drive
what is your platform, lap or desk top?
what OS? what version.
USB external>?
beeping, that must be the USB tones, ding ****, USB just say a connection, right? and if you right click the USB icon in the tray
and see , the name and (mine shows, drive F:)
you can also (what OS ? and version)
go to the (run box type "disk management" and run that)
bingo see all disks, and all partitions.
it must have a drive letter, and mine says, Monster 2TB.
for a volume label.
Oct 01, 2013 | Toshiba Computers & Internet
IT MAKES A BEEP AND DOESNT OPEN THE FILES
it is not getting enough power. Use a two ended USB plug (both ends into computer) one into HD, or use external power adapter. Do no continue using it. The two ended USB cable should have come with the drive.
Jul 10, 2011 | Iomega (34959) 500 GB USB 20 Hard Drive
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
My external drive is beeping at about every second and it is not being recognized by my computer
when you hear this it some times mean you are not getting enough power to the drive or the drive is dead and you can just throw it away. if it is an external slim drive and it has a mini usb to 2 usb cables then plug both cables in the usb slot on a pc.
Feb 24, 2011 | Computers & Internet
My iomega 320gb hard drive is just beeping when it's plugged in. I've tried plugging it into other computers, trying different USB ports, uninstalling it from my computer then letting it reinstall...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 25, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
My WD external hard drive does not stay recognized on my computer. When I first plug it in it makes the ding/beep noise and shows up on "my computer" but after a few seconds it makes the ding/beep noise...
Try the hard drive on another computer to see if it is the external or a laptop interface problem. There are EIDE/SATA to usb adapters that you can connect a hard drive to that the computer will then read as an external hard drive. The problem with external HDDs is the usb interface built into them, these are mounted on controller cards and that is ususally where the failure occurs.
Jan 10, 2010 | Western Digital Passport 320GB External...
Computer does not recognize external drive. Drive beeps.
i am unsure about this but try going to start control panel administrative tools services plug and play and see if it is enabled and has auto start-up type and that should enable your computer to to recognize new devices
hope this helps i really do
Mar 25, 2009 | Computers & Internet
Beeps and computer not reading USB port
usb drive get faulty. replace it.
Oct 03, 2008 | Computers & Internet
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
Dell Precision T5500 Computer Workstation   PC Desktop Logo
76 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
