Question about Kitchen Ranges
Chain flies off of Stanley quiet glide garage door opener How to adjust Do not have an owners manual How to get one online
  • 2,841 Answers
Stanley Vemco, Quiet Glide, LightMaker, Home Innovative, Whistler, Popular Mechanics, and SecureCode were all manufactured by Stanley Works and parts are interchangeable. Replacement remote transmitters, receivers, keypads, some circuit boards and other parts are available at our store.For Stanley gate opener and garage door opener parts and accessories go to Stanley Garage Door Opener Parts
Instructions, schematics, wiring diagrams, adjustments, and additional help with problems and repairs for stanley garage door opener can be found in the owner's manuals.
The following are manuals I have found on other websites. I do not guarantee their accuracy or continued availability.
Available manuals from Marwest Access Controls, Inc.: Chain, Screw and Cable (for Stanley garage door openers from 1982 to Current.) $7.50 each
Stanley Code Key Instructions - (dual-technology)
Stanley Code Key Instructions - (non-secure code)
Stanley 1050, 1094, 1082 coding instructions
Stanley Lightmaker & SecureCode Transmitters coding instructions
From Stanley Garage Door Openers back to Brands page
The Stanley Garage Door Opener has not been manufactured since 1997. Parts can be difficult to find. You probably cannot find parts locally, but some are still available online.Stanley Garage Door Opener Parts
Posted on Aug 20, 2010
Stanley garage door opener model 440. need a manual
Try Googling (Stanley)(440)(manual) without parens.
Apr 02, 2018 | Building Materials
My stanley garage door opener's chain snaps everytime i open with remote
have you checked the chain tension adjustment for proper amount of deflection? This is listed in the manual that comes with your garage door opener. Usually, the chain is too loose from the problem that you are describing. I would check online for the manual if you don't have access to yours. Also, the travel adjustments for stop (up and down resting positions) would be explained as well.
Oct 06, 2012 | Home Security
HELLO, IS THERE ANYWHERE TO DOWNLOAD A OWNERS MANUAL FOR A STANLEY PREMIER 4100.43 GARAGE DOOR OPENER THAT YOU KNOW OF?
http://www.garagedooropenerguide.com/stanley.html
Not great info, but there are links to email the remnants of the Stanley Garage Door company (the companies using the Stanley name went bankrupt), as well as some links for parts.
There is also this link for Stanley Garage Door manuals from the page above: http://www.aaaremotes.com/stowma.html
Feb 28, 2011 | Stanley Garden
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Apr 01, 2010 | liftmaster Chamberlain Garage Door Opener...
Garage door will not open
You can fix this by loosening the chain enough that you can lift it off the sprocket. Then run the opener until the sprocket turns counterclockwise and stops. Now with the door in the open position replace the chain. This will get the chain running the right direction. You will have to adjust the open and close limits along with the force adjustments but that will all be covered in your owners manual.
May 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to tighten chain on stanley model # 3220.50 Serial code 9101
IT MAY BE ON THE FRONT END OF THE RAIL.
MANY OF THESE ADJUST WHERE THE CHAIN CONNECTS TO THE TRAVELER.
DON'T MAKE IT TOO TIGHT THE BUSHING AT THE POWER END IS PROBABLY ABOUT GONE (THIS IS WHAT CAUSES THE CHAIN TO GET LOOSE) LEAVE A SAG OF ABOUT 1.5 INCHES.
ALSO START WATCHING THE ADS FOR A GOOD DEAL ONCE THE BUSHING IS GONE THE UNIT IS TOAST - PARTS ARE NOT AVAILABLE FOR MOST STANLEY UNITS.
Nov 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
GARAGE DOOR OPENER
Refer to your owners manual to adjust the travel limits to stop the door opening too high
Apr 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Ranges Logo
450 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
