Question about Kenmore HE2 Plus Front Load Washer
Shows F24 on the front of the washer. Was washing clothes on the express cycle and it stopped mid cycle.
  • 15,935 Answers
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the "F24" Error Code. Some of the error codes on these model washers can be erroneous, however. The first step in troubleshooting any error code is to simply unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of the washing machine. If the error code reappears following a CCU reset, then you have a genuine problem.
"F24" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor.
To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a 2 x 4 under the front feet of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Make sure this plug is secure and not loose or unplugged. It is common for the connector plug to come loose due to vibration. If the plug is intact, check the contacts for corrosion. If everything appears as it should, then unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((**))))
Posted on Sep 28, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
    what's f24 code? - Kenmore Elite HE3 Washing Machine ...
    https://www.ifixit.com/Answers/View/85549/what's+f24+code
    iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
    F24 Error Code on My Kenmore Washer ' eHow
    www.ehow.com > Home
    F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
    Kenmore HE2 Plus Front Load Washer F24 error code ...
    www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
    ...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
    I have a Kenmore HE2T error code F24 - Fixya
    www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
    Dec 9, 2009 - Posted on Dec 09, 2009.
    Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
    Look under the machine cabinet for
    a bag with the diagnostic manual
    Oct 16, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
    Samsung wf317aag stopped mid cycle now machine has no power
    First, are you sure there is power to the unit? Check the breakers and post back.
    Nov 03, 2012 | Samsung WF317AAG Front Load Washer / Dryer
    LG Tromm WM2496HWM Washer - stops mid cycle
    use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
    Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Need to get in and take clothes out mid cycle
    Press stop/cancel.
    The timer will advance to the end of the cycle and drain the water so you can open the door.
    Mar 29, 2009 | Kenmore 44102 Front Load Washer
    Error code f24
    F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
    Possible causes:
    • Too cold of water or hot water is turned off
    • Temperature sensor failure or loose connection
    • Control board failure
    Dec 18, 2008 | Kenmore Washing Machines
    Kenmore HE2 Plus Front Load Washer Logo
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
