Question about GE Dishwashers
GE dishwasher GLDL500N10BB (2 year old)began to run eratically 2 months ago. Would run a cycle then restart and continue like that for hours. Sometimes it would run a partiaal cycle and stop. Finally no start at all. Have dor off and no visible wiring issues, water, or other obvious issues
  • lowfin1269 Aug 20, 2010
    I forgot to mention that sometimes it would work fine. Heating element was working each time it would run. There is not a visible mechanical timer. This is a solid state unit with a circuit board for the touch panel and a control panel.
    Both panels are dry. I am going to order a main and tactile board kit.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 20, 2010
  • Rylee Smith
    Rylee Smith Aug 20, 2010
    OK then the issue is with the control panel. However, before replacing the panel you take it off and try to blow air with the help of hair dryer so that if there is any moisture it blows it off.
  • Rylee Smith
    OK, Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Dishes leave food particles on the glasses - machine is only 2 years old. We use rinse agent - Cascade gel in the auto dispenser - we use jetdry dishwasher cleaning agen monthly - jet arms are not...
Recent changes in the law prevent soap makers from putting phosphates in dishwasher soap so they're not as effective as the were even a few months ago.  Unfortunately,  the solution is more thorough rinsing before loading.
http://www.appliance.net/2010/states-ban-phosphate-laden-dishwasher-soap-1988
Mar 03, 2011 | GE Dishwashers
My 5 month old LG dishwasher is making a high
Good day-
I am the proud owner of a LG LDF6920WW. I bought it 10-2008 and it developed a high pitched sqeel (HPS) exactly 2 years and 3 months later. It first occurred on a monday and repeated on the following Wednesday. After the water filled the machine and the swirling, pumping, cleaning cyale began, the HPS began and lasted until the drying cycle. I searched the internet and determined that this HPS was occurring anywhere from 5 days of being purchased, up until the 2 year mark. I was weary of believing that a motor would fail in a five day period as well as last for up to 2 years, so I "Googled" parts for my model and looked at the scematic or parts break down chart. Refering to the chart, I began to disasemble my dishwasher after removing it from the cabinet and taking it to the garage.
I focused on the sump assembly. I removed all parts, motors, baffles, bladders, check valves, etc. I thougroughly cleaned all pieces and parts with windex and a scotch/sponge. I removed all food and debris from all surfaces and gaskets. I cleaned the main body cover by using a low pressure hose and alternating cleaning the top and bottow. I made sure not to rip the micro screening. Upon re-assembly I used high heat, automotive bearing grease to lubricate the seals where motor shafts protruded through them. ****Important**** I set the clutch setting at 3 on my electric drill to screw the assembly back together. I also disassembled the water inlet valve and the float assembly on the left side, exterior of the dishwasher and cleaned that completely out. I flushed all hoses as well.
I put it back in, connected all water, electricity and back-flow devices. The dishwasher is once again silent. All motors and bearings seemed fine. During tear down, the only problems I found were: 1) A lot of debris in several places. 2) dry gasket to shaft surfaces.
Jan 19, 2010 | LG Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
The dishwasher starts to fill wwith water then stops but
Most likely faulty door switch
Slght possible the control panel is shot but door switch is cheaper and just as common
Aug 27, 2009 | GE 24 in. GSD4020Z Built-in Dishwasher
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
1995 Saturn SL2 Continues To Stall
I had same problem a couple years ago with 95 sl2, i had new wires and plugs instaled and they replaced the valves also. car works great since then...
Jan 07, 2009 | Saturn SL2 Cars & Trucks
Whirpool quiet partner dishwasher seems to have no power
Ok there is a thermal fuse mounted on the control board that shuts down when it gets too hot. Did you run a sanitize cycle? Even if customers dont use the sani cycle which i recommend the fuse may open due to poor wire connections. The new fuse kit comes with a new harness and new connectors. Check the old fuse to be sure its bad. Dont remove the connectors from the new switch at all - dont disturb them and they will work better.
Dec 02, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
89 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
