Question about Car Audio & Video
I have an mtx thuder 1501 amp there is a redlight on,but no sound, any solutions??
  • 58 Answers
Check and make sure you have twelve volt turn on power. Then disconnect your speakers pop them with a battery to make sure they work and connect them one at a time. You also need to check your input source.
Posted on Aug 20, 2010
  • joshuavince Sep 30, 2010
    plsss help me plsss
I have 4 mtx 9500 12in subs 2 of them is on a mtx 92001 and the other is on a mtx 4001d . would it be better to run all four on the mtx 4001d. for more power and a better sound or how should i run this set...
NEVER mix different power amps. Depending on the ohms of your subs, sell one of the amps, up to you. The 4001 has more power, but either amp will do the job, the amp needs to see a 1 ohm load, so your subs have to be dual 2 ohms, or single 4 ohms to do this. If your subs are dual 4 ohms then you will have to run your amp at 2 ohms which would be have the power, or a half an ohm, (Not Recomended) and be at double the power. You may be able to do a competion sound off and just "Burp" the subs, but at a half an ohm, dont expect to listen to it to long before it goes into protect and shuts down.
Sep 06, 2011 | MTX Thunder Elite TE4001D Car Amp
I need to know what ohm level my 1501 d class mtx thunde is?
Connecting a single speaker, speaker impednce should be equal to or greater than 1 ohm. Connecting 2 speakers, each speaker's impedance should be equal to or greater than 2 ohm
Dec 19, 2010 | MTX Thunder 1501D Car Audio Amplifier
I have a mtx thunder 7801 and a sledge hammer box
Sounds like the subs are blown with the voicecoils fused together which means the amp is/was seeing a dead short ( zero Ohms reisitence) not good for any amp. Disconnect the speaker terminals from the amp and see if it turns on. The funny smell might have been the subs blowing up, i'll keep my fingers crossed for you.
Feb 28, 2010 | MTX Car Audio & Video
Car stereo
check your amp to see if its on high or low setting in order for it to bump it needs to be on low thats all the bass settings and you shouldnt hear the words come out of your subs
Nov 01, 2009 | Car Audio & Video
MTX 1501 SCHEMATIC DIAGRAM
MTX never released any of their schematics.
What sort of problem are you having with it?
Sep 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Mtx TC-6001 Amps Problem
I had same problem with a TC6001 and get solution from MTX, not send to MTX instead MTX kindly sent a quotation for parts to be replaced, I can tell you what parts need to be replaced if you still need a solution.
Jul 12, 2008 | MTX 6001 Car Audio Amplifier
MTX TC2002 amplifier has a noisy gain control
Not really, other than sending it to MTX or an authorized repair shop.
Jul 11, 2008 | MTX TC2002 Car Audio Amplifier
Lost...
The 1501 is very similar to the 81000 but there are important differences. The 1501 is a better amp.
If you turn the gain up and down, does the woofer move in and out in direct relation to the rotation of the gain?
What do you mean by "you only feel current going through subs"?
May 09, 2008 | MTX Thunder 1501D Car Audio Amplifier
MTX 1501 D
If the terminals were smoking, it's probably due to loose screws in the terminal block or wire that's too small.
Did the amp work properly after the terminal blocks smoked?
Apr 29, 2008 | MTX Thunder 1501D Car Audio Amplifier
Hi i have a mtx 1501 d
If it does it with no RCAs plugged in, the speakers or wiring need to be checked.
If the speakers and wiring are OK, the amp may have shorted output transistors.
Apr 10, 2008 | MTX Thunder 1501D Car Audio Amplifier
Car Audio & Video Logo
297 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
