Hotpoint wma40 i have to clean out pump and rubber pipe from drum to the pump and pump due flood of washer in kitchen the problems is the when i took pump out and disconeted the wires the little plastic clip that surrond the terminals that stop it going in anyway i can put the surron back on but it will go on 2 ways i need to know wich way this clip need to go back on or wich way the blue and brown wire goes on the pump ie wich side of pump does brown wire goes the pump is 16402004/04 plastec cod.69132 220/240v-ac 50hz-30w clfo42003 any help would be apreciated and thank you
    Problem Solver:
  • 13 Answers
Hi, how many terminals does this particular plug have that goes to the pump? If it only has 2 wires and the pump is AC rated (as it appears to be in your description) then it wont matter which way you connect it. However if you have another wire there (ie for earth / ground connection) it will matter.
Posted on May 04, 2008
Hotpoint aqualtis aqxxf149hpi is showing a error h20
Check tube to water pressure switch. The wall of the rubber tube on my machine had worn through due to friction. Taped it up to make sure this was the problem. No H2O code and machine working!
May 27, 2014 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma40
hi take the band of rubber just inside door take soap draw out take screws out holding panel this comes of dont pull wires of control panel or mark were they go take kick plate off you have screws holding bottom of panel top ones are under top panel take two screws holding catch out were door clips in push panel up you can get to front of drum to take off takes about 15 min oh sorry top off 1st hope this helps
Jan 29, 2014 | Hotpoint WMA40 Front Load Washer
Hotpoint WDD960 F13 code, water not pumping out.
hi if you wash small childrens clothes such as small socks they can get between the door seal and drum. they then get trapped in the rubber hose between the drum and pump which would create the problem you are describing.you would find this hose under the washer.
Jun 25, 2013 | Hotpoint Ultima WF860 Front Load Washer
Can sumet be blocked in my washer as wen it spins the water dont empty and i get a flood out the door and powder part
You need to clean the filter.
Remove lower rear panel of washer, locate and remove large black hose on bottom of drum.
Remove and clean plastic filter inside the hose.
Jan 22, 2011 | Hotpoint WMA40 Front Load Washer
The water wont drain out of my hotpoint machine
Remove lower rea panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Oct 21, 2010 | Hotpoint WMA40 Front Load Washer
Stopped half way through cycle and won't drain! any ideas?
Probablyu a blocked filter or pump.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remoive and clean filter inside hose
Check pump for blockage as well, and the drain outlet hose..
May 21, 2010 | Hotpoint WMA40 Front Load Washer
Hi could anyone help me please..My Hotpoint WMA52 keeps flooding
It is not draining properly, or overfilling due faulty pressure switch.
Try cleaning the filter first.
Remove lower rear cover of washer.
Remove large black hose onto bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Hope this helps.
Dec 07, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Hello i have a hotpoint wma40 the machine will go
Hi, i have a wma40s had it for 7 ears now same thing happended would start a cycle but then stop halfway through make the noise but the drum would not spin etc. i bought some carbon brushes of ebay for 7 quid and it works better than its worked in years bit nosiey for first few washes but after it settles it is as good as new.
Jul 06, 2009 | Hotpoint WMA40 Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Water coming from soap dispenser
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this fi
Feb 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
