Question about LG Washing Machines
Front loader will not expel the water. - LG Washing Machines
    Sergeant:
    Champion:
  • 311 Answers
There are only 3 things this would be- clogged pump trap, blocked pump impeller or the drain pump is not functioning. You would need to investigate these to get to the fault. I assume you have the aptitude to do what is needed here as I cannot offer anything but advice. You must do the work needed.
Posted on Aug 20, 2010
Stopped spinning after washing,water remains in the tub
usually what happens here is that the pump to expel the water is not functioning, the normal problem here is a coin or hair grip gets lodged in the pump and stops the impeller from turning, generally the pump can be removed and opened up to remove the offending article and allow the impeller to operate again, once cleared of obstruction reassemble the pump and refit it. ( be aware, as the machine is still full of water, when you remove the pump the water will flood out so you need plenty of towels so soak up the water that spills.
Sep 24, 2016 | Washing Machines
Water is being held under the basin
That is normal, never is all the water expelled by the machine about 1/2 gallon remains in the tub on front loaders. If the water level is showing in the visible part of the washer basket you have a problem.
Feb 02, 2012 | GE GTWN3000MWS Washer
Bosch front loader washing machine door not opening
The door will not open if the machine detects excess water in it. Run the drain or spin cycle to check if water is being expelled. If necessary check the pump filter for obstructions and the outlet hose for blockages. If this does not work you may have a problem with the pressure system, the door lock itself or a crack or break in the handle and it is not catching the lock mechanism, let me know if this helps or if you need further assistance.
Nov 24, 2011 | Bosch Washing Machines
Ytek.netwe just moved into a house with a duet washing machine- a few years old. when we do a normal clean cycle, it doesnt appear there is that much water getting used. How much water should we see thru...
All front loaders use very little water as a opposed to a top loader that uses up to 45 gallons per load a front loader uses about 10,plus a front loader cleans clothes very well with that minimal water usage.
The major question is do the clothes seem to come out clean when you have used that washer?
Aug 20, 2011 | Whirlpool Washing Machines
Need a part diagram or technical drawing for my asko w600 front loader. have cleared a blockage in the impeller that expells water so it fills and empties, but now it wont spin. Brushes i'm thinking?, can...
hello any spin problems can be down to the module board this control the motor speed this usually sits at the back of the of the washer may have a load of wires coming off it hope it helps
regards
shaun
Mar 19, 2011 | Washing Machines
My electrolux ewf 1481 front loader wont spin
Open the flap, bottom right of the front panel and check the filter is clear. Most machines will not spin until they have expelled all the water. You may want to check the hose is not block and any connections to the sink if it's not on a standpipe.
Most new machines have quite sensitive out of balance detection so if it an odd load try again but add a few extra items to allow the machine to distribute the load evenly prior to spin. Hope this helps
Jul 07, 2010 | Electrolux Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
My front loader isnt rinsing my clothes damp
Check to see if the lint filter is overfilled. If so, simply slide it out and remove accumulated lint. Next, check if the exhaust tube from which hot air is expelled is blocked. Clean it out as best as you can - it's possible that a bunch of lint has accumulated inside.
Aug 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not expel water
yes. replace the drain pump motor.
Jan 04, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
