Question about Monark VL32 Bion Velometer (SpeedPaceDistance)
How do you activate the watch? Mine will not come on.
  • 28 Answers
Battery issue?
Posted on Sep 01, 2010
Why do i need to interrupt a tv in the home for my tv to continue to work
Many if not all providers charge you for a set maximum number of active connections to their service. If for instance you are recording something and also are watching 4 TV's in your home and are paying for 4 TV's, it will tell you to turn something off because you are trying to use 5 connections.
Nov 29, 2015 | Televison & Video
Reset radio code
Acura and Honda Radio COdE Retrieval and Unlock Tips ...
? 5:13
www.youtube.com/watch?v=tgfRmBo7Pu0
Nov 13, 2009 - Uploaded by Factory Car Stereo Repair Acura and Honda Radio COdE Retrieval and Unlock Tips .... mine is Honda Accord 93, click what button to active it? .... Radioreset code in 5 minutes for a 2001+ Honda CRV CR-V Accord Civic Pilot Element Odyssey Insight ...
Oct 21, 2015 | 1995 Honda Accord
Is it compatible with L G tv? I cannot get mine to show movies or activate setup mode.
You should press SOURCE option of your remote and select DVD . When you finish watching your DVD, select source again to go back to TV
Jul 22, 2015 | GoVideo DV2130 DVD Player/VCR
Orbit heart rate monitor watch operating directions
when mine did this i changed the battery and it worked properly again.
Sep 29, 2013 | Exercise & Fitness
Want to silence the hourly ''beep''--no manual.
There was another, previous problem posting that was identical to mine, although for a different watch. The solution given also worked for my watch.
Hold in Reset button and note whether all days of the week appear in the display. If they do, the chime is active. Press the Mode button to de-activate: days of the week disappear. Done.
Thanks
Mar 25, 2009 | Watches
Mutli purpose TV control
To add or remove an Activity, click Add an Activity or Remove an Activity.
• To customize an Activity, click Customize next to an Activity icon, and then click the appropriate
option.
• To change the names of Activities click Customize next to the Activity icon, and then click
Rename Activity name.
• To have more than one Activity of a given type (e.g. If you have both a cable converter and a
satellite receiver, you can add a second Watch Television Activity) click Add an Activity. When
you're done, rename the Activities to help you distinguish between them (e.g. For the Watch
Television Activity you could rename one "Watch Television" to "Watch Cable" and the other to
"Watch Satellite
Dec 12, 2008 | Logitech Harmony 880 LCD Remote Control
Emergency brake bypass
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 23, 2008 | Car Audio & Video
Setting the time on a Timex Data Link 851 Watch
You have to use the USB cable and do it through your computer. There is no way to change the time on the watch. Bad design.
Dec 31, 2007 | Watches
Monark VL32 Bion Velometer (SpeedPaceDistance) Logo
254 people viewed this question
Top Monark Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Monark Exercise and Fitnes Expert? Answer questions, earn points and help others
