Question about Kenmore Elite HE3 Steam 8674 Dryer
When I press start all I hear is a click. All the lights are working and the tumbler is free and moving in both directions. Is it the termal fuse?
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Aug 20, 2010
My 2007 chev aveo wont start and cant move gear shift
most cars the brake light switch has to work properly for it to come out of gear and start properly. check this switch! Also First check to see if you have brake lights (if not the switch may have failed) secondly when with the ignition key on when you press the brake pedal do you hear a click from the area of the gear shift lever each time you press the brake pedal? If not the control module, wiring or solenoid may have a problem. First check all your fuses! Hope this helps, Good-Day!
Jul 27, 2014 | 2007 Chevrolet Aveo Sedan
2001 ford f150 4x4 does not engauge
We may need more details. Does your 4wd dash light illuminate? Do you hear clicking from the dash? If it does not, you are dealing with a fuse or transfer case issue. If you see the light and hear clicking, it likely is not your transfer case but either your 4wd solenoids (attached photo) on the passenger side firewall or the actuator on the front differential. Pop the hood and listen for clicking from the solenoids, if the click, direct your attention to the actuator. It is vacuum actuated so it should move about an inch when engaging and disengaging 4wd. It sometimes gets stiff so see if you can move it by hand to free it up.
Feb 01, 2014 | 2001 Ford F150 Styleside SuperCrew
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    May 31, 2011 | PNY Optima Pro 2GB Secure Digital Memory...
    At-pl120 getting power from cord, hear on/off switch clicking, opened witnessed contact move, yet no power, zip nothing? any ideas, isaw no fuse inside near power inlet thanks need ansswer asap so i can...
    is this belt or direct drive. if its belt try replacing the belt if its direct drive and your hearing it turn on and the platter doesnt budge when you press start the motors blown. I hope This helps, by a Stanton next time not the expensive ones just a nice direct drive table .
    May 14, 2011 | Audio Technica AT-PL120 Turntable
    Turn the key and the engine makes a click noise only and wont turn over. lights and accessories work so i believe battery is good. iam thinking starter or soliniod ?
    Yes, if it is making a loud clicking noise it is most likely the starter. The solenoid is working...that is what you hear clicking. Doesn't matter...you get both when you buy a starter anyway.
    Feb 06, 2011 | 1993 Buick LeSabre
    Ribbon in Printer Idle error
    xgech if using ribbon, change the seting to Direct termal, if not, change to Termal transfer. save,(press 2x the enter button) restart the printer
    Nov 05, 2010 | Zebra S4M Thermal Label Printer
    My drivers seat does not move. I have a 2001 xj8 jaguar. What should I check for?
    Check for obstructions (sorry-have to start here)
    1) get to a very quiet place
    2) trigger the switch to move the seat
    2.a) if you hear an electronic single click, the motor is probably burned out
    2.b) if you do not hear the click check the fuses
    2.b.1) if not fuse, take to dealer for inspection diagnosis...this should be done free of charge
    Jul 11, 2009 | 2001 Jaguar XJ8
    Power is on all the time with or without the key in the ignition. There are no positions (ie...accessories, on, start). When the key is inserted it moves freely in all positions. I removed the steering...
    ok some where on the tumbler there will be a very small pin hole you will have to put the key in turn it forward one click then take something that will fit in the pin hole and push in and pull out on the key this should remove the tumbler then follow the directions on the new tumbler to put it in
    Jun 06, 2009 | 2001 Ford Ranger Regular Cab
    How do we get to the termal fuse on a maytag dryer
    hi yES IT COULD BE THE THERMAL FUSE . tWO SCREWS AT BOTTOM OF DRYER REMOVE FRONT PANEL tHETHERMAL FUSE IS LOCATED ON THE AIR VENT TO THE LEFT OF THE ELEMENT . THANKSFOR THE QUESTION THE APPLIANCE DOC
    Jul 25, 2008 | Maytag PYE2300AY Electric Dryer
    Kenmore Elite HE3 Steam 8674 Dryer Logo
    43 people viewed this question
    Top Kenmore Dryers Experts
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
