Question about Sony STR-DE575 Receiver
Replaced 20" Sony with 32"...KDL32EX301. Old TV was wired into STR-DE575 receiver...old RCA wires still attached to receiver...no access to change (in motorhome). Where should the RCA wires be plugged into tv in order to get TV sound thru surround system. DVD plugs fine into side panel with all 3 yrw wires to get surround sound. Can't seem to find the right input or output jacks to get the tv surround sound working through the receiver.
fairlane
  • 50 Answers
SOURCE: Unable to hear dvd audio when dvd playing on Sony STR-DE575
Hi The first thing to do is disconnect the red and white audio cables from the back of the receiver, and plug them directly into the tv. If you then have sound from the DVD, then you have eliminated the possability of no audio coming out of the DVD player. If the DVD player checks out fine, then I would try plugging the jacks into another aux input on the receiver, and select that and see what happens. Also, if there is a "tape monitor" button on your Sony, make sure it is turned off. I'll assume the receiver has sound from other functions, so it would be rare for one of the inputs to just stop working, (but certainly not impossible), I'm not familiar with that model, and normally I would say it could just be a dirty selector switch, but since you mentioned having a remote, then switching between inputs is done by the microprocessor, not a physical switch, so if you cannnot get sound through using another input, then it could be expensive to repair. Hope this helps, and good luck!
Posted on Apr 30, 2007
welcomejee
  • 10594 Answers
SOURCE: sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Posted on Jan 04, 2009
mlapres
  • 757 Answers
SOURCE: Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Posted on Dec 23, 2009
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
Grubhead
  • 5190 Answers
SOURCE: Center Channel not working
First of all check that it has not got switched off somehow. After that, what I would do is trace the wires back (inside the unit) from the center speaker connector. This will take you back to the output semi-conductors for that channel. I would suspect these first, you might even see damage! You should anyway be able to look the numbers up on the net. If they are cheap I would replace them anyway. If that doesn't work I suggest you hunt down the service manual, it might have suggestions in it.
Posted on Apr 08, 2010
  • 5 Answers
SOURCE: Sony STR-K670P Surround Reciever. No output from
This is a common problem that a lot of people have with this system. The problem is in the connection of the Left and Right Speakers to the receiver. I had this problem too.
What you need to do is actually open up the receiver using a screwdriver. Once it is opened up you will see a circuit board and lots of wires. Look for the red and blue wire that should be pretty easily visible. Cut each one, then strip the ends some, and reattach the ends but to the opposite color- make sure to solder it as well. On some models they messed up the connections and it got switched. Once you do this, the left and right speakers should work great. Hope this helped!!
Posted on Sep 22, 2010
Is it possible to connect an iPOD to the Sony Receiver STR-DE598?
go hood with it an take a pair of audio rca jacks cut one end take an old head phone wire cut the end about six inches splice them hook the pos to the pos of the rca an the neg to the neg tape each one so they dont touch each other an plug the rca side into the receiver plug ur ipod or phone in an turn it to the aux mode an bamm works on car an house stereo,,,,Thats what we do at 3am an thers no where to buy a wire,,,,,,B^D l^nDz....215.....*$*$
Nov 08, 2011 | Sony STR-DE598 Receiver
Sony STR-DE575 5.1 Channels Receiver I have power to everything but I am getting ZERO sound. Is this something that is fixable or do I just need to replace my receiver?
Have you looked in the manual? Basic speaker setup with test tones will certify the basic hardware. Then onboard FM. Then add the compexity of external and digital sources.
Aug 26, 2011 | Sony STR-DE575 Receiver
Apr 08, 2010 | Sony STR-DE575 Receiver
Sony str-dg820. having a problem getting video on tv
Jan 04, 2009 | Sony STR-DG820 Receiver
How do I hook the STR DE 575 up to my tv?
Usually if you have a Cable or Satellite box, you would hook up a Fiber Optic or Digital Coax cable from the Sat/Cable box to the Sony Receiver. Then for HD, an HDMI cable or componet cables from the Sat/Cable box to the TV
Dec 18, 2008 | Sony STR-DE575 Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Cables
you coudl use a single rca to a left and right rca cable. However most woofers will have a lfe single rca input on the woofer that you connect to a single rca on the receiver.
Are you sure you are not confusing the +/- on the woofer that is used to connect your speakers? ie. my woofer has the +/- so i can connect to my front speakers and my receiver to filter the low frequency sounds via the woofer.
hope this helps
smeags.
Feb 19, 2008 | Sony STR-DE575 Receiver
Sony STR-DE575 Receiver Logo
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
