Samsung Monitor I just brought this monitor 2 days ago and its stuck on standby mode. I am not sure how to fix the problem and I've checked connections, source input and still not working.
  • 4,102 Answers
Hi, Have you tried leaving it unplugged for about 30 min then switch the monitor on before you boot your comp up,
Let me know what happens ok
Posted on May 03, 2008
  • paul proctor May 03, 2008
    Hi sorry forgot to ask what model number is it
Sleep mode
A Google search indicates this is a common problem.. Some of the comments in this video may help. If it is still under warranty, you might be best to get a RMA. Good Luck.
How to fix Samsung monitor that is stuck in sleep standby mode Temporarily
Oct 26, 2017 | Samsung BX2450 LCD Monitor
Samsung 931bw screen flashes on and off
unscrew the back cover of the monitor then remove to access the power supply board, look for a leak or blown up electrolytic capacitor. just replace with the same rating and value a panasonic brand of capacitor much better with low esr.
Jun 28, 2012 | Computers & Internet
Monitor is switching off immediately after system is switched on. Again when monitor is switched on, images appear for about 3 seconds and again monitor switches off.pl give the solution.
You need to determine if you is turning off or going into standby mode. When your monitor shuts off, the power light will turn orange if it is in standby or the light will turn completely off if the monitor turns off. If your monitor goes to standby, that means that your monitor is losing signal which indicates a problem with your PC. #1 Make sure cable is firmly secured and both screws are tight #2 Check your video card make sure that it is firmly in its slot. Take it out and put it back in. *as long as your computer is open give it a good cleaning with compressed air* If those things check out it is possible that your video card has failed and needs to be replaced.
If your monitor is powering off #1Check plugins- try something else (i.e. lamp) in the outlet #2 Try your PC's power cord in your monitor
Oct 21, 2010 | ViewSonic Computers & Internet
The led is blinking and the screen is flashing and stays black, no picture or desktop appears and monitor menu doesn't work when power on comp after being off for few hours or longer, Tried with changing...
Make sure that your computer isn't going into Standby or Hibernate mode. You can test this by briefly pressing the power button and wait to see if the screen comes back on.
Oct 26, 2009 | Samsung 943NW Monitor
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
I have an asus mother board with athlon64 3800+ cpu. I have two dual head nvidia geforce 6600 vid cards ea. w/ 1 pcie and 1 pci output to sli and vga, respectively. I barely know what I'm talking about...
sounds like your computer is going into standby or sleep mode. Does hitting enter on the keyboard turn it back on? Does pressing the power button turn it back on? One of those should do it.
You can change it so it does not do this, In windows xp you can goto power options in the control panel, and change system standby to 'never'. Not sure in vista probably about the same thing.
If this doesn't help then maybe you have a hardware problem.
- Dave
Dec 11, 2008 | Computers & Internet
Samsung 216bw Stuck in standby mode
hi try putting near rad or uses and hair dryier, i hope thie work
chers
Dec 09, 2008 | Samsung SyncMaster 216BW Monitor
Computers & Internet Logo
437 people viewed this question
David Payne
David Payne
