Question about Refrigerators
Our 3-door traulsen freezer had new seals installed (incorrectly) which caused the freezer to stay on continously for 12 hrs. The compressor was frozen with ice and the temp increased to 22 degrees. I shut off the unit but what do I do?
  • 4,793 Answers
When you say the temp was increased to 22degrees you do mean
-22C not +22.if it was minus 22C then just ensure seals are on correctly and leave it switched on it will settle down to -18C in its own time....do not use any heating on the compressor,just leave it.
Posted on Aug 20, 2010
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Traulsen Refrigerator Freezer in a home installation with a separate comressor skid installed in the garage. I am havinf difficulty with the frezer compressor. Should I repair the freexer...
at the end of the day its all down to costs
first ask yourself how old is this compressor?
how much to fix it and re-gass it?
if you pay to fix it, how much life is left in the old girl?
how much for a new compressor?
now,,,how much life will be in that one???? years!
not a hard choice,,but all down to costs!
Jun 05, 2010 | Traulsen UR48DT-6 Refrigerator/Freezer -...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
The coils behind the stainless back panel are caked with ice. I have defrosted them...now what.Fridge won't stay cold and ice keeps building up.Unit is 17 yrs. old. traulsen freezer/glass door fridge ERS...
may be you have problem with the Evaporator fan motor not running, defrost heater, defrost timer, open gap on door gasket and bad thermostat (cold control), it may kept the compressor constantly running. Good luck.
Jun 27, 2009 | Traulsen Refrigerators
2 door freezer from traulsen never get cold,compressor is running
check the freon level. Most likely low on that. Many other things can cause this but start there and let me know if we need to go farther.
May 29, 2009 | Traulsen G20010 Commercial Refrigerator
Why does my maytag fridge drip water around the freezer door?
Freezer door frames have a small heating element in them to stop that happening. Your element is failed.
Torn gasket seals just cause frost inside, but also cause the compressor extra stress if the seal is bad. This causes the compressor to keep running as yours does. They are cheap to buy and easy to fit.
With a 12 year old one, it is probably time for a new one. The new ones are more energy efficient and are cheaper to run.
Mar 23, 2017 | Sub-Zero 650 / O Bottom Freezer...
Commercial Freezers
I have worked in a lot of kitchens and don't really have a preferance. The top mounted compressor is better for you as it is easier to service and leaves more cabinet room. Dirt and dust also stay near the floor. YOu won't have to clean the filter as often up high The disadvantage to this in a kitchen is that kitchens are hot and up high is hotter still. Order a cheaper model. No glass doors, no stainless steel. You don't need these features.
Jun 24, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Traulsen 2 door freezer
Traulsen Freezer Compressor Change Out Video
Dec 05, 2007 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
