Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
How to clean the viewing screen - Hitachi 46F500 46" Rear Projection HDTV-Ready Television
  • 1,476 Answers
Terrybasilio,
I have a tip at http://www.fixya.com/support/r4690955-clean_lense_screen_in_projection_tv which explains how to do this safely and properly.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Aug 20, 2010
How can i clean the screen
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user\'s manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV\'s can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can\'t tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it\'s extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions. GA_googleCreateDomIframe(\'google_ads_div_TL-IMU-Article\' ,\'TL-IMU-Article\');
Jun 09, 2010 | Mitsubishi WD-65732 65" Projection HDTV
There seems to be dust behind the screen panel i live on a gravel road is there a way to clean the screen or what do i do
What you have to do is remove the front screen assembly by removing the screws loacted at the bottom of the screen frame just under the frame lip. Lift the screen assembly up from the bottom to disengage the holder clips at the top and set the screen assembly to the side. On the inside of the screen, the part that faces the projection mirror assembly you can use some Windex and paper towels to clean the surface. On the outside do not use Windex as this will breakdown the protective finish used on the viewing side of the screen. To clean the viewing side, use a special cleaner also used to clean computer display screens. Re-install the screen assembly and you are done.
Jan 21, 2010 | Hitachi 61SDX01B 61" Rear Projection...
What should be used to clean the TV viewing screen
Soft cotton cloth would be fine to clean front screen of TV. Do not use any liquid or detergent in cleaning.
Thanks.
Nov 21, 2009 | Sony KDS-60A3000 60" HDTV
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
Water Damage to View Finder
Try cleaning the viewfinder with a damp (again?) soft cloth. You can use a product recommended for cleaning camera lenses. You can still use the screen to view the scene you want to shoot. (I am assuming that what you call the viewfinder is the small eye that used to equip all cameras, before it was replaced by the view screen.)
Hope it helps.
Sep 08, 2009 | Sony Cyber-Shot DSC-W220/B Digital Camera
Camera says it's taping but video not visable
clean the video heads - either a cleaning tape or a good hand cleaning by a qualified tech.
Mar 04, 2009 | Panasonic AG-DVC10 Mini DV Digital...
Record video try to view VTR get blue screen and no sound on lcd screen
Seems video head is dirty/ clogged. Use good quality Video Head Cleaning Cassette please.
Aug 09, 2008 | Sony Handycam CCD-TRV43 Camcorder
Viewfinder Obstruction
If the dust/dirt is visible in the finder, it is in one of three locations: - if very sharp, it is on the "grind" side of the viewing screen, which, unfortunately for cleaning ease [unless the screen is user-removeable], is often the upper side of the screen in newer cameras. - if fairly sharp, it is on the non-"grind" side of the screen, and it may be possible to remove it with a VERY soft (very clean!) small brush or a VERY gentle blowing with a hand syringe-type blower (blowing hard into a VF area just about guarantees that dust will be blown in). - if very soft-looking, it is on the underside surface of the pentaprism (being able to clean the VF area without a repair is an excellent arguement for having the interchangeable-screen feature...). Prevention is the best way - never leave the body cavity uncovered (except briefly, when changing lenses); never change lenses in a windy area; keep the rear area of the lens clean; get in the habit of facing the open camera downward while changing lenses; NEVER blow into the body cavity (unless you know what you are doing, the mirror is up, or the screen is removeable). Hope This Helps
Oct 27, 2005 | Nikon Coolpix 3200 Digital Camera
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
