Question about GE WBSR3140DW Top Load Washer
The clothes have to be spun 2/3 times to get them dry enough for the dryer.
  • GE Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 20, 2010
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Water and moisture build up
this sounds like the clothes are not spun out enough in the washer. there could also be a blockage in the ducting that would cause condensation bulit up but it sounds like you have a lot of this very unusual
Sep 05, 2009 | Frigidaire Electric Dryer
Some heat, not enough
you have a lint problem recommend cleaning the whole dryer and the best thing for the lint screen is toilet bowl cleaner... weird i know but it works really well..
Apr 30, 2009 | Dryers
Roper dryer res7745pq is taking 2 cycles to dry and vent is clean?
check if the thermostats in rear part of dryer are covered with lint. take power off to dryer and remove back panel you will see 2 or 3 thermostats if there is a lot of lint around them carefully remove lint. if that doesn't solve problem make sure clothes are coming out of washer spun dry enough .. check lint screen on dryer. is the vent clear all the way outside ?, in winter little critters like to set up housekeeping in vents where the temperature warms them up. you can also check if heat is cycling open door to dryer and press the door button, start dryer and observe heater , it will come on then shut down and it should come back on in a minute or two, if it doesn't come back on the cycling thermostat may be at fault
Jan 26, 2009 | Dryers
My Mratag electric dryer does not dry clothes like befor I have to run it twice most of the time
1.Inspect your vent to the outside for lint build up or other foreign obstructions.
2.Make sure your lint filter is cleaned after each cycle.
3.Observe if your clothes are being spun dry enough out of the washer.
If none of these help, let me know and we can delve deeper into the issue.
Thank you for contacting FIXYA.com
May 28, 2008 | Maytag Dryers
Cloths not getting dry
id look into a clogged and or kinked exhaust vent. perhaps where it leaves the home theres a screen over the housing thats clogged itself w/lint. its generating heat, thats good now just needs to release it somehow
Mar 16, 2008 | Washing Machines
My clothes are not completly dry when I dry them for about 56 minutes.. at times I have to dry my clothes as much as 3 times to get them dry I have tried putting less amounts in with no luck. It seems to...
Reset your two circuit breakers. Check all vents and vent lines. Check your lint filter and its receptacle. Is all the water being spun out by your washer first?
Dec 16, 2007 | Whirlpool GEW9250 Electric Dryer
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
GE WBSR3140DW Top Load Washer Logo
51 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
