Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
I need part # for fuel cap modle 30223 ser 6057 tractor
    President:
  • Toro Master
  • 1,545 Answers
Maybe try and get the manual which may have all the parts and part numbers lister here: http://www.manualsonline.com/
Posted on Aug 20, 2010
Why does my scott lawn tractor s1642 stop running after about 5 minutes?
Check your fuel cap. If it has a vent that isn't working, the fuel tank will build up pressure because no air can get into the tank and will then prevent fuel from getting out to the engine. You may need to replace the fuel cap. If so, you can get one at PartsBuggy.com.
Dec 01, 2012 | Garden
Fuel leaking around fuel cap on my tractor
The fuel cap is vented and does not seal like a water bottle so leakage when the fuel level is over the cap would be normal.
Aug 27, 2012 | Garden
How to replace the fuel tank pressure sensor
Generally they are located on top of the fuel tank. On some modles you have to replace the whole inlet/access assembly. On others you can replace just the sensor. Check it over in a repair manual for your make/modle. Also, replace your gas cap, if it leaks it can give a false sensor reading if the cap can't hold pressure.
Aug 31, 2017 | 2000 Buick Park Avenue
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
Jan 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere 2020 diesel. I can't get the fuel pump off
You need to remove the nut under the cover in front of the pump and then borrow a tool from a j.d dealership to pull the coupler off the pump,you may need the dealer to do this because they have a no lend pollicy for their special tools.Hope this helps.
Nov 10, 2009 | John Deere Tractor Side Screen...
DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Jul 16, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
66 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
