Question about Bose Companion 2 Series II Multimedia Speaker System (2-Piece)
Bose speak cable was accidentally pulled out of computer and I cannot understand how/where to plug it back in. Dell xps 420
  • junehelsabec Aug 20, 2010
    Thanks for your answer Tech 114. There are 2 jacks at the end of the Bose Companion 2 Series II speakers cable (red
  • junehelsabec Sep 01, 2010
    Thanks tech 114. I now have sound. JuneHelsabeck
    President:
  • 1,851 Answers
The 3,5mm jack from your speakers must be connected at the GREEN 3,5mm female jack (at the back panel of your dell, NEAR the blue, orange and black jacks, just above the USB connectors). Maybe this photo will help you:
In case you have another audio card and you're not using the onboard with the computer, the connections is a little different. In that case post a reply to clarify for you.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 20, 2010
Testimonial: "Thanks tech 114 for your help. I now have sound."
  • Stelios
    Stelios Aug 20, 2010
    Let me try to make it easy. Use the audio cable to make the connection.
    • Insert the stereo mini plug at one end of the cable into the mini audio out jack on your computer (at the green one as I told you before)
    • Insert the two plugs (usually one red and one white) at the other end of the cable into one pair of the AUDIO INPUT jacks on the right speaker. In details: Insert the white RCA plug into the white jack labeled L. and insert the red RCA plug into the red jack labeled R.
    • A speaker cable is attached to the rear of the LEFT speaker. Insert the free end of this cable into the jack marked TO LEFT SPEAKER on the back of the RIGHT speaker.
    Here is the full connection diagram:
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
    Thank you tech 114. The red
    New Friend:
Go to the front of your house and open the closest hose bin valve and then turn off your main line. Let it run on off until most of the waterm in the system drains out. Don't close the hose bibb yet. What it's happening is the air in the system is purging out. You can sometimes hear the air comin out. What I do most of the times is open closest valve to the problem area, in your case, I would open the hot side of the kitchen faucet and then slowly turn on your main shutoff valve, not to slow but not to fast either, that's one reason you get water hammering. Once you see a good glow of water turn off hose bibb and how inside and wait till you get a full blast of water coming out from the jot side. You're differently will hear air coming out and water after. After that turn off faucet. If that doesnt solve it, you might have someone go under your house and see if the pipe is fastened securely.
Posted on Jun 02, 2017
My XPS 420 desk top won't accept my SD card
back up pics on sd card then format, reload pics and retry
Sep 10, 2014 | Dell XPS 420 PC Desktop
Xps 420 fan
as long as it has the same connector than yes. fans are usually the same when it comes to personal computers
Mar 05, 2014 | Computers & Internet
Identify correct network card for dell xps 420
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Nov 29, 2012 | Dell Ethernet Card Network Adapter
Xps 420 air temperature sensor
I would remove your fan & heat sink to check that your thermal paste isn't dry first.
Jul 15, 2012 | Dell XPS 420 PC Desktop
I have Dell destop model XPS-420 my computer is not getting on NO FAN and no noise please advise me what should I have to do
hi
are you saying the fan is not working ? if that's the case, you need to replace the fan.
get the service tag # located on back of your desktop PC, go to this link below, place service tag in appropriate box . it will give you part numbers for the peripherals of this computer. locate the fan and purchase replacement.this is all you have to do. DO NOT TURN ON THE COMPUTER UNTIL THIS FAN IS REPLACED, or you will damage the mainboard and/or CPU.
http://search.dell.com/results.aspx?smh=sup&c=us&l=en&s=dfh&k=XPS-420%20&cat=sup
Nov 14, 2010 | Dell XPS 420 PC Desktop
My Dell XPS 420 will not turn on. Power light
Hey! Nice Computer! ( At least while it was working! Specifications show some high-end hardware parts)
Steady amber light on the Power On light, means a bad power supply.
The Dell XPS 420 uses the standard ATX style of power supply found in 90% of computers out there.
(Personal computers. Not the Cray Supercomputers!)
This is Dell Support, and the User Manual - Removing and Replacing Parts - part of the manual,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1466871
From Me:
1) Computer unplugged from power, computer case open. TOUCH the metal frame BEFORE you reach inside.
Your body carries Static electricity.
Static will fry out computer hardware components.
You won't see it, or feel it.
Computer unplugged from power, you are safe.
Touch the metal frame Before reaching inside, your computer is safe.
Should you get up for any reason, walk away, then return, Touch the metal frame again)
You either have a 375 Watt, or a 425 Watt power supply.
I would recommend a power supply with more Wattage, and more Amp's on the 12 Volt power rail.
The Dell XPS 420 comes with an Intel Core2 Duo processor, or an Intel Core2 Extreme processor.
These puppy's can use a lot of power when gamin', or other intense programs are being used.
The Nvidia GeForce 8800 Series of graphics cards offered, use a lot of power when maxed out.
The motherboard with the Intel X38 motherboard chipset, uses a lot of power.
I would recommend a 600 watt power supply for a replacement.
My recommendation would be an OCZ StealthXStream 600W
Why?
1) If the temperature of this PSU is kept under 118 degrees Fahrenheit, the PSU can put out 728.8 Watts reliably. (47.9 degrees Celsuis)
2) It has Four - 12 Volt power rails.
EACH power rail can handle 18 Amps.
That's a total of 72 Amps!
3) It has all the power cables you'll need.
A) 20 + 4-pin ATX motherboard power cable
B) 8-pin 12 Volt power cable (8-pin EPS)
C) 4-pin ATX power cable
D) SATA power cables [ 3 ]
E) Peripheral power cables, (4-pin Molex) [ 6 ]
F) 6-pin PCI power cables. [ 2 ]
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=106
Not advertising for the above website, nor the PSU manufacturer. Recommendation supported by personal preference, and experience.
Information about the various PC power cables and connectors,
http://www.playtool.com/pages/psuconnectors/connectors.html
Jan 04, 2010 | Dell XPS 420 PC Desktop
Hooked up my Bose companion 3 series II speakers but cant get sound. Which input hole do I put the audio cable? I put in the speaker jack that the original ran off of but its isnt working I have a dell xps...
Hi there , and happy new year ... The Cables are usualy Colour Coded , so try plug the Green Color coded Wire into the Green Jack Socket ...make sure it isnt connected to the Microphone socket..
Hope this Helps Bud
Have a Great Year: )
Dec 30, 2009 | Bose Companion 3 Series II Multimedia...
Xps 420 keeps freezing or going to blue screen
Same with my Dell Vostro 420. At this rate I will just buy a new PC as I am wasting too much time on this. We tried usual stuff like cleaning inside, making cooler, removing certain virus software, still no luck. I have to restart 4 times a day and keep saving material. Can only restart by turning it off by pulling out power socket.
Jun 24, 2009 | Dell XPS 420 PC Desktop
Dell XPS 420--Sound
Check if the sound is available on your control panel >> Sounds
Check on the back of your computer if the speaker is connected on the right port (usually green hole)
Oct 01, 2008 | Computers & Internet
Bose Companion 2 Series II Multimedia Speaker System (2-Piece) Logo
618 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
