Question about Xerox Phaser 6115MFP/N Laser Printer
Error code 17h - Xerox Phaser 6115MFP/N Laser Printer
  • Xerox Contributor
  • 185 Answers
Rack rotation failure. First, turn off the unit. See if the toner carousel can move.
It may be binding mechanically, or have a bad position sensor 130E11800 , or a bad motor 127E15270.
The mechanical problem will be the hardest to solve, because there isn't 1 easy answer.
Whit
Item, Inc.
Posted on Aug 20, 2010
17h error, paper comes up the back and stops gives this error
Error 17H is a rack rotation failure:
The toner cartridge(s) may not be sitting correctly, which would be the easiest fix - otherwise you have to carefully examine the inner workings of the printer itself, to see what is causing the rack to get jammed or slowed down at some point along the way.
Nov 20, 2010 | Konica Minolta magicolor 2400 Laser...
Fatal error 17h
17H is the Rack Rotation error. If your toners are not rotating correctly, or if you have the wrong type (IE 2400 series toners in a 2500 series printer) you will get this error.
Feb 18, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica/Minolta 2490 copier that has a service code 17H what is this
17H is an error for the toner , either they are not in all of the way or the latch is not closed....to fix it simply take out the toner and put them back in making sure the latch is closed all the way :-)
Oct 03, 2008 | Minolta Office Equipment & Supplies
Konica Minolta 2300 DL
Just sent you the manual.
Regards
Wayne
Oct 02, 2008 | Konica Minolta magicolor 2300DL Laser...
Where are the toner cartridges in magicolor 2300 dl
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing
rack rotation
open door, remove waste toner box then you have to find a small switch in left side and push it wit screwdriver or something, then you can rotate the toner rack manually. then install the waste toner box again and power up printer.
Sep 01, 2008 | Konica Minolta magicolor 2300DL Laser...
Fatal error 17H
FATAL ERROR CODE 17H / SERVICE CALL 17 TONER RACK: Incorrect developing rack rotation
<Remedy>
Electrical components for detection of the malfunction
Rack motor (M2)
Rack clutch (CL1)
Rack home position sensor (PC4)
Master board (PWB-A)
Controller control board (PWB-P)
Rather than try to explain in more detail i can forward you the service manual (4.17mb) if you update with an e mail address
Jun 05, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta Magicolor Fatal Error
Remove each of your cartridges one at a time and see if you can spin the toner rollers by pushing on the little white plastic gears with your finger. They will be tight but you should be able to spin the roller by moving the little gears around.
My printer started giving the Fatal Error Code 17H and I did all the removal of the four color cartridges and re-seating each of them to no avail. After removing each cartridge and checking to see if I could rotate the toner roller I found that the yellow cartridge was extremely tight. I took the cartridge outside and used a can of compressed air to blow all the toner off the roller and tapped the cartridge on all corners and shook it back and forth several time. Finally I was able to get the toner roller so that it would rotate when pushing the little white gears like the other three cartridges.
After replacing the cartridge in the printer it worked with no more error codes. Hopefully this will fix the problem until I can order a new yellow cartridge.
Keith
Jan 07, 2008 | Konica Minolta magicolor 2300DL Laser...
Errors
Rack rotation failure, I'm not 100% that this is that error, but does the rack, where the toner are move ? if not, move it with manually a little bit then restart printer.
Nov 14, 2007 | Konica Minolta magicolor 2430 DL Laser...
Xerox Phaser  6115MFP/N Laser Printer Logo
418 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
