Question about HP PSC 750 All-In-One InkJet Printer
Greetings, Thank you for your help. I have a hp psc 750 printer. 1. I want it to be in English and it it is set for Spanish. 2. color is not working. thank you.
  • 1 more comment
  • barbaracleve Aug 21, 2010
    I want to focus on the color print cartride. It is full. I cleaned the black ink cartridge but do not know how to clean the color cartridge. Thank you.
    I am all set on the English. Thank you.
    I do not want to copy color, I want to print color. Please check that you are looking at the right printer. Start scan is on the bottom then copy is above it with both a blank and a color button.
    It just tries to copy something in color. Does not help the printing in color.
    Is there a way to clean the color cartridge?
  • 4,472 Answers
So when you print in color, does the unit print in color at all? What about when you print a test page? have you run any of the maintenance available by right clicking the printer and going to properties in the printers and faxes folder. You go to printers and faxes by going to Start>control panel>printers and faxes. Once I have more information I can assist you further.
Thank you,
Lee
Posted on Aug 21, 2010
  • Lee A.
    Lee A. Aug 21, 2010
    If the problem persists there could be a problem with the print head itself. I would consider replacing it as a comparable replacement is only about 40$.
    Thank you,
    Lee
I have used this copier for years. Never had a problem. Have used LOTS of color cartridges. There is ink in the cartridge but it will not come out!
  • HP Master
  • 4,924 Answers
For the language ..just press the manu ...than choose from arrows to the maintenance ( vigilancia will be the word in Spanish ..probably ) ..and than select language ..(idioma) and select inglese ..
if it do not print color ...see that it has 2 buttons under the start ...one from the bottom up ..the left one is for printing B/W and the green one in the right is for starting to print colors..
  • Catalin Turcu
    Catalin Turcu Aug 21, 2010
    yes you are right ...the power is up in the left and the start scan is the one on the bottom ...and the copy in color has to be activated to make prints in color..its the same thing cause when you copy ..in color it prints in colo r..just try it ..cause in the menu I do not see anything else that will activate the b/wand color printing ...here is a map with all the menu ..
    http://bizsupport2.austin.hp.com/bc/docs...
    Genius:
  • 1,478 Answers
If the color is not working, you will need to check the color cartridge to see if there is ink inside the cartridge, it is possible the ink level in the cartridge is low or the cartridge is defective, in this case, i will advice you get another cartridge and see the performance.
On the second issue, i will suggest you follow the instruction on the user manual, the manual is the best guide in this case.
Take care.
Posted on Aug 20, 2010
How do I put my psc 750 on English it is on Spanish now/
1 Press Menu. 2 Press -> until Maintenance appears, and then press Enter. 3 Press -> until Set Language and Country appears, and then press Enter. 4 Press -> until the desired language appears, and then press Start Copy, Black or Color. 5 Press Start Copy, Black or Color to confirm. A prompt displays asking to select the country where your HP PSC will be used. Specifying the country sets your photo sizes applicable for your region. 6 Press -> until desired country displays, and then press Start Copy, Black or Color. 7 Press Start Copy, Black or Color to confirm
Feb 22, 2011 | HP PSC 750 All-In-One InkJet Printer
HOW DO I SET IT BACK TO ENGLISH LANGUAGE? ITS STUCK ON SPANISH.
Setting the front panel language
  1. Press the Menu button four times. When the Maintenance setting appears in the display, press Enter.
  2. Press the Right Arrow key four times and press Enter.
  3. The available languages will flash on the display, but they can also be accessed with the navigation keys. Select the desired language by pressing the Black or Color Start Copy button.
  4. Confirm the selection by pressing Black or Color Start Copy button again or press Cancel to try again.
  5. Press the navigation (ARROW) keys until the correct country appears in the display. Press Black or Color Start Copy button.
  6. Press Black or Color Start Copy button again to confirm the selection or Cancel to try again.
Dec 15, 2009 | HP PSC 750 All-In-One InkJet Printer
The language on my printer screen is spanish, I don't know how to change it to english
follow this steps Go to Menu > Maintenance > Set Language & Country/Region > Press Start for English > hope this helps
Sep 01, 2009 | HP PSC 750 All-In-One InkJet Printer
On my hp psc 2210 all-in-one printer, I can't change the
hi friend,
1. Press OK to open the menus.
2. Press < or > to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Navigate to System Setup menu
5. Select Language
6. Change to English
7. Select OK
http://www.tangerineofficesystems.com
http://www.d-rod.com
http://officeworldadvice.blogspot.com
thank u for using fixya
regards
sivaranjini
Aug 06, 2009 | Xerox Phaser 8400 Laser Printer
My HP PSC 750 printer screen seems to be in German. How do I get an English display? Diana
CLICK HERE for your owners manual in PDF format.
Page 36 of the manual states the following -
HP PSC 700 Series
The following steps help you change the language for your unit.
To do this using the front panel
Press Menu.
2 Press until Maintenance appears, and then press Enter.
3 Press until Set Language and Country appears, and then press Enter.
4 Press until the desired language appears, and then press Start Copy, Black or
Color.
6 Press until desired country displays, and then press Start Copy, Black or
Color.
7 Press Start Copy, Black or Color to confirm.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 04, 2009 | HP Office Equipment & Supplies
Cant get it to read in english
Change the front-panel country or language on HP PSC 750. (From HP PSC 750 manual - bpu02250.pdf)
1 Press Menu.
2 Press a194261.gif until Maintenance appears, and then press Enter.
3 Press aa48bd2.gif until Set Language and Country appears, and then press Enter.
4 Press 98782b3.gif until the desired language appears, and then press Start Copy, Black or
Color.
6 Press b3bb801.gif until desired country displays, and then press Start Copy, Black or
Color.
Feb 01, 2009 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1610 Language reset
Press SETUP until you see 4. PREFERENCES. (Spanish-Preferencias) Press OK.
Press RIGHT ARROW until you see SET LANGUAGE & COUNTRY/REGION. (Spanish-Idioma & Pais) Press OK.
Press LEFT ARROW or RIGHT ARROW until you see ENGLISH. (Spanish-Inglés) Press OK.
When Prompted, press OK.
Press RIGHT ARROW to select the country. Press OK.
When prompted press RIGHT ARROW to select Yes or No. Press OK.
Here is a link to the User Guide. It's on page 93.
PSC1610 User Guide
Nov 25, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu04829&dlc=en&product=57769
It works !
Aug 22, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 750 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
