Hi MY laptop is running very slow - Computers & Internet
    Problem Solver:
  • 12 Answers
For the better performance delete cookies,temp files from the computer.
Uninstall all the unwanted softwares from the computer.
Run disk clean up
  1. Open Disk Cleanup by clicking the Start button Hi MY laptop is running - 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking All Programs, clicking Accessories, clicking System Tools, and then clicking Disk Cleanup.
  2. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. If the Disk Cleanup: Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
  4. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
  5. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer.
.To run disk defragmentation.
1. Open the Start Menu. A) In the white line (Start Search) area, type dfrgui and press Enter.
OR
B) Click on All Programs, Accessories, System Tools, and then on Disk Defragmenter.
Increase the virtual memory of the computer.
How to increase Virtual Memory?
In Windows XP
1.Click Start, and then click Control Panel.
2.Click Performance and Maintenance, and then click System.
3.On the Advanced tab, under Performance, click Settings.
4.On the Advanced tab, under Virtual memory, click Change.
5.Under Drive [Volume Label], click the drive that contains the paging file that you want to change.
6.Under Paging file size for selected drive, click to Custom size check box. You can enter the amount of memory you would like to reserve for Virtual memory by entering the initial and maximum size.
7.Click Set
When you are prompted to restart the computer, click Yes.
Special Note: You should choose the same amount for the initial size and maximum size. This will Stop your CPU from constantly changing the paging file.
HOT TIP: To stop your CPU from constantly changing the paging file, set the initial and maximum size to the same value. For example, 500 and 500. The value should be at least 1.5 times more than your physical RAM. If your computer has 512MB of RAM increase the virtual memory paging file to 1.5*512= 768
In Vista
1. Click Start button Picture of the Start button
2. Click Control Panel
3. Choose System and Maintenance and then click System.
4. In the left pane, click Advanced system settings.
5.On the Advanced tab, under Performance, click Settings.
6. Click the Advanced tab, and then, under Virtual memory, choose Change.
7. Click Custom to change the Initial size (MB) and Maximum size. See the hot tip above.
This will improve the performance of the computer.
Thanks.
Posted on Aug 21, 2010
My laptop runs to slow why? Gene
Hi Sally.
I am assuming you are asking about Cortana.
Cortana is a voice activated personal assistant that you can use to get Weather forecasts, remind you of appointments and/or dates, send email, Etc. A lot of people find this program helpful, and a lot of people find this program annoying, ( BECAUSE IT SLOWS THEIR COMPUTER DOWN). You can disable this program two ways: 1st way, launch Cortana from the search bar on the task bar, click settings from the left pane, and under Cortana the first option I believe, slide the button switch to the off position; 2nd way, type gpedit.msc in the search box to open the editor, go to Local computer policy/ Computer configuration/ Administrative templates/ Search. Then double click the policy named allow Cortana. I believe this is it for the second way. Hope this helps. Let me know.
May 27, 2017 | Computers & Internet
Frozen Laptop
If it is not overheating, try running the free version of Advanced System Care.
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
Sep 11, 2015 | Toshiba Computers & Internet
Hp pavilion runs slow
Hi ,
I recommend taking your unit back to the retailer , otherwise waranty could void .
Regards .
May 02, 2014 | HEWLETT-PACKARD Computers & Internet
My acer aspire v5 laptop running to slow
The only solution is to run a factory default recovery, but you could also try installing Mozilla Firefox and see if that helps.
Feb 01, 2014 | Acer Aspire Computers & Internet
Hi My Laptop is very slow in booting and
Try to run a diagnostic on the hardrive and memory. Dell has a built in diagnostic. to run the built in diagnotic, make sure the laptop is turned off. Hold Fn, then press power button. you will see the diagnostic screen. after running the diagnostic and you didn't see any errors, try to reinstall the Operating System. try to isolate the problem first before replacing the parts. if reinstalling the OS still makes the computer slow, better call Dell tech support.
Feb 23, 2010 | Dell Inspiron 6000 Notebook
I was on my computer the other day and it went really slow what is wrong?
Hi there;
As you are using dell inspiron 1501 pc notebook it has operation system windows Xp and as your laptop is running slow you can try some of the following steps
1)click on start>>run>>in run type prefetch and delet all folders
2)click on start>>run>>in run type temp and delete all folders
3)click on start>>run>>in run type %temp% and delete all folders
all theses folder contain the junk files and if have too many junk files in these folder your system will run slow
the next step that you can follow is stoping the software running automatically which are another reason to make your system slow inorder to stop the software to run automatically you have to follow
click on start>>run>>type msconfig
go to start up tab and unchecked the software that you don't want to run by them self and then click on Apply button and restart your system
you can also try to scan the system with anti virus to make sure your system is not running slow
Regards
Om
Oct 19, 2009 | Dell Inspiron 1501 Notebook
Very slow to boot
That's a sign of too many applications loading at startup. Click on RUN and type MSCONFIG / STARTUP tab. Uncheck any items like photo software etc. that don't need to run at startup. Also if you're running Norton antivirus or any other Norton products, loose them. They're resource hogs.
Hope this Helped!
Oct 11, 2009 | Computers & Internet
How do i know what programs i can take out of this laptop? it is running so slow.
You can see what programs run in your system by pressing ctrl+alt+del keys together. then click task manager which will have the list of all the applications running. If you find a particular application making your computer work slow, then click on that application in the list and then click end task which will close that application.
One solution for your computer running slow could be reformatting your operating system. Your system might have been affected by virus which could be the reason for your system's bad performance.
Hope it helped!
~regards,
Jegan
Jun 01, 2009 | Dell Inspiron 1521 Notebook
Internet runs slow or freezes on my wired desktop when I use the internet on my wireless laptop.
Hi tech_newbie.... Need a little more info... how is your wireless connected.. ethernet /Usb... or true wireless... and vice versa for desktop. where is your wireless router situated... what times are you experiencing the slow connection!
In addition.. first try running a good Spyware/ adaware programme such as Spybot.. and alongside side another programme called... a-square.. and with AVG.. all of which are free... see links below..
http://www.safer-networking.org/en/download/index.html
http://free.grisoft.com/doc/2/
http://www.emsisoft.com/en/software/free/
Try this first.. they are all pretty good programmes when used in conjunction with each other, you;ll be surorised at what you find.... Get back to me if this does not eliminate your problem
Regards Faggly
Mar 19, 2008 | Computers & Internet
Slow packets
it could be to do with what programs you have running when windows running in normal mode or it could be a virus scanner program or internet sec program you running
Sep 24, 2007 | HP Pavilion Dv5130us (ET806UA) PC Notebook
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
