Question about Samsung RM255LASH Side by Side Refrigerator
A wire touch and shoot fire and my refrigerator when out is there a reset button on it
    President:
  • 1,891 Answers
Ther is no reset button . but do ck the house fuse . if the lights in frig work the power is ok but something is burnt out in frirg . the wire that caused this ?? needs to be repaired or the problem will happen again ..mm
Posted on Aug 20, 2010
Kindle fire will not charge-got a new charger and it still will not charge- does it need anew battery and how do I do that?
The Kindle touch and the Kindle FIre are great devices for your reading needs. However, there are times when it becomes unresponsive and freezes on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch/fire. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding.
  • Hard and soft reset
    Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.
  • this might help you.
Dec 22, 2014 | Amazon Kindle Fire HD
Whirlpool refrigerator ED2FHEXNQ00 - water shoots out the front
USE AT YOUR OWN RISK!!!!
I ACCEPT NO LIABILITY FOR PERSONAL INJURY OR PROPERTY DAMAGE.
YOU CAN BE KILLED IF YOU DON'T UNPLUG THE REFRIGERATOR!!!! EVEN AFTER UNPLUGGING IT, BE PRUDENT TO NOT TOUCH BARE WIRES OR TERMINALS.
If it is like my Kenmore, there are two solenoids at the back bottom right (facing the back) of refrigerator where the water supply connects to the refrigerator, and it sounds as if both solenoids (one for water dispenser and the other for ice maker) are energized at the same time as though the hot wires to the solenoids are shorted together. Possibly, if the replacement icemaker is not an exact replacement, a wiring difference might cause this short. ONLY IF YOU ARE QUALIFIED TO DO ELECTRICAL WORK will I suggest the following. YOU CAN BE KILLED IF YOU DON'T
UNPLUG THE REFRIGERATOR!!!! Disconnect one wire at a time by pulling and wiggling from side to side if the connectors are fastons , and with an ohm meter check for a short between the two hot wires of the solenoids. Remember where each wire goes. To determine which are the hot wires first measure each wire to a bare metal place on the refrigerator. Continuity between the wires (2) to the bare metal indicates ground. The remaining 2 wires are the hot wires. Continuity between these wires indicates they are shorted together, which is the cause of your problem. Seek out the short. Since I am not an expert myself, the preceding suggestion may not work if the short only occurs at the time that the icemaker calls for water.
I ACCEPT NO LAIBILITY FOR PERSONAL INJURY OR PROPERTY DAMAGE. YOU CAN BE KILLED IF YOU DON'T UNPLUG THE REFRIGERATOR!!!! EVEN AFTER UNPLUGGING IT, BE PRUDENT TO NOT TOUCH BARE WIRES OR TERMINALS.
Aug 16, 2014 | Whirlpool Refrigerators
Fuel injectors not working
Possible ECM not seeing cam or crank signal to fire injectors
Jan 21, 2014 | Ford Ranger Cars & Trucks
No lights inside or outside and will not work on dc either, do have 14 volts going to unit
On the back of the refrigerator there will be a red wire going from the 12vdc connection block over to the heat riser tube and will plug into a thermal switch. The red wire will have a black sleeve on it which covers and inline diode. If you do not have 12 volts at that switch then the diode is bad and must be replaced. (It is a fire prevention safety device and must be installed on the refrigerator.) If you do have 12v at the input of the thermal switch but not at the output then the thermal switch has tripped and needs to be reset. Simply press the center reset button.
Sep 02, 2013 | Dometic RM2652 Refrigerator
Kindle Fire Factory Reset My kindle fire has a
Press and hold the reset button 40 seconds and then press again and see if it helps.
Jun 19, 2017 | Kensington Amazon Kindle Fire / 2nd...
Is there a reset button
No,
There is no reset button on a chest freezer...
here are some tips that will help to trouble shoot the compressor problem...
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 15, 2010 | Whirlpool 7 cu. ft. Chest Freezer EH070FXM
Nail gun double fires
There is one main part that can be the cause of the problem.
The trigger. Check to see if there is anything out of the ordinary with this. There should be some moving components attached to the trigger itself. Is any part of the trigger touching the button in the body of the gun when safety is not depressed. If the lever on the trigger is pushing on the button, even a little bit, It will allow the gun to fire again and again.
Mar 12, 2009 | Air Tools & Compressors
Refrigerator Compressor hot to touch & fridge/freezer not cooling
you need to do an amp draw with your meter,clamp the run wire on the compressor,you should get 2-5 amp reading,any higher means the compressor is going bad,also should be a locked rotor amp(LRA) reading on comp.-mike
Nov 04, 2008 | Kenmore 53542 / 53544 Side by Side...
Sb800 doesn't flash
Let's force the flash to fire:
nstalls four fresh batteries.
Turn on flash, do not connect to camera
Wait until flash is ready
Get a small wire with insulation and strip both ends about 1/8".
With one end of the bare wire lead, touch/hold CENTER TIP
Contact(silver pin from flash).
Make sure flash head is not pointing at your face.
With other end touch bare wire to OUTSIDE Contact (silver on
outside of hot shoe that rides into camera hot shoe rails-this is ground).
Flash should fires, gets a flash out of the flash tube.
If not, you have flash problems.
You most likely hurt the flash by using the dome filter on top of flash.
Over 80% photographers are doing this way when shooting flash photography. And 95% for wedding photographers.
This will shorten the life of the flash.
Even more with that adapter parked onto the flash.
Hope they are helpful to all photographers.
Suggestions or comments,
atdlee@netzero.com
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
Refrigerator part does not get cold
Here is a link to a trouble shooting guide for three models similar to your download or open the PDF and pages 27-30 are for the list of trouble shooting tips, Hope I have been of some help,
 Thanks Sea Breeze
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MFD2561&siteCd=MT_EN_US#owners_manuals
Oct 27, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Samsung RM255LASH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
