Question about Car Audio & Video
I changed batteries on my 2001 cadillac deville, and my radio will not work. I need the unlock code for my radio
    President:
  • 2,309 Answers
The code is in the owners manual , if lost the dealer will need the serial no of the radio and the car to supply code
Posted on Aug 20, 2010
How can I recalibrate my 2001 deville
recalibrate what , PCM/ECM ? engine computer . Disconnect battery cables and touch them together for 10 min.
Jan 23, 2017 | 2001 Cadillac DeVille
Tip
DISCONNECTING YOUR BATTERY without losing the RADIO CODE
I constantly read frequent requests for RADIO CODES referring to the disconnection of battery power ( whether its for changing the battery, etc.) and the radio is now INOP. Here is a simple way to save radio codes, radio stations, clock time and computer settings. Purchase from an auto parts dealer, a 9 volt battery powered lighter socket connector. Plug into lighter, do your battery work, After work is completed, disconnect, and radio will work as before. Unit will cost less than 20.00 and well worth it.
on May 11, 2009 | 1993 Cadillac DeVille
Unlock code for a 2002 cadillac sedan deville radio auntie theft lock
There is no unlock code - each radio is programmed with the VIN of the vehicle in which it was last installed. The only way to reprogram it to a different vehicle is with a Tech II scan tool (GM Dealer).
Feb 07, 2015 | 2002 Cadillac Deville
2002 cadillac deville can't unlock radio even though I have code
are you sure you have the correct code ? if so dissconnect the battery for a few minutes to allow power to drain down replace the battery earth wire ,try the radio again if unable to enter code i would say the radio will need replacing
May 10, 2014 | Cars & Trucks
My 2001 cadillac deville radio needs the unlock code can u help please
Welcome to FIxYa.com
Mainly you will need the serial number, VIN , and proof you own the car and go to the dealer they will help you for free.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 25, 2010 | 2001 Cadillac DeVille
Will a cd changer from an 2000 cadillac deville work in an 2001 cadillac deville
Yes it will but your going to have to go tot he dealer to activate your radio. The radio is programed to work with the ECM's VIN number and replacing the radio with another radio will not recognize the Vin number and will not activate.
Thank you for using Fixya and good luck.
Mar 30, 2010 | 2001 Cadillac DeVille
My 2001 cadillac deville keeps giving me dtc code system to lean
Anytime I get a too lean DTC I first change the fuel filter if it hasn't been changed in awhile. You'd be surprised how many times this has helped.
Good Luck with it.
Bob
Oct 22, 2009 | 2001 Cadillac DeVille
I need the stereo wiring diagram on a 2001 cadillac deville
2001 Cadillac Deville Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 13, 2009 | 2001 Cadillac DeVille
2001 cadillac deville theft lock on after replaced battery help!
IF when you purchased your car you didn't set your own personal code you will have to take this to your local GM dealer and they can pull the code that is set at the factory and unlock your radio.THe proceedure for setting your own code then unlocking radio is in your owners manual.The dealership I worked for did this for free.
Aug 30, 2009 | 2001 Cadillac DeVille
2001 cadi deville wont start new starter battery is good , remote will notlock or unlock door , trunk wont open either with remote open trunk
I'm sure you've checked, but will the headlights come on? Radio? Any sign of power? Did you check the battery voltage under the hood? Our 2001 was dead. No signs of life at all. I checked the voltage and was approx 3.5V on new battery. I pulled the back seat and measure straigt off the battery. 11.89V. Believe it or not, had loose connection for no rhyme or reason. Tighted battery connections and we're back on the road. Just a thought.......
Feb 27, 2009 | 2001 Cadillac DeVille
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
