Question about Gaggenau EB984 Electric Single Oven
Re: EB 846-6 Gaggenau electric built in oven My electronic display was failing and then the display and oven failed altogether. And so what to do:
ctf1800
  • 4402 Answers
SOURCE: oven
go here
http://www.gaggenau.com/AE_en/Home.do
the customer support
then operation manual
Posted on Dec 04, 2007
SOURCE: Gaggenau EB294/295 Electric Double Oven
I am a gaggenau engineer this is usually a fault with the door lock mechanism it can be manually reset eg remove oven and side panel pull back locking arm there is a also a built in test prog in oven clock that will switch door lock back to reset position but these will need to be done by an engineer as oven very heavy.
ring 08705 678910 for service and/or advise
good luck
Posted on Dec 19, 2007
  • 1462 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
i suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Posted on Jul 18, 2008
  • 12 Answers
SOURCE: Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Posted on Sep 01, 2008
  • 10 Answers
SOURCE: error code F 20 on Gaggenau EB 260/262 oven
Sometimes the error light will come on because of mixed signals sent. If everything works, then just ignore it. Unplug the oven or turn power off in fuse box. This may reset the light control. Be very careful around the power source. Wear rubber bottom shoes, have dry hands and floor. Don't touch exposed wires with anything. This is 240 volts that can hurt or kill you!!!!!!
Posted on Nov 03, 2009
Testimonial: "Appreciate the advise, but would still like to know the exact meaning of error code F 20. Thanks."
Gagenau eb270 fuse location
I do not think there is a master fuse like on US built ovens. Power goes directly to the controls
Jun 06, 2014 | Gaggenau EB 270/271 Electric Single Oven
I need to remove our Gaggenau EB 846-600 for some cabinent refinishing. I am trying to find information to remove this? Any installation manuals or owners manuals floating around? Thanks Shane
Hi Shane,
I have the same oven so I have the "Operating and Installation Instructions" manual. Just not sure how we can connect?
Victoria
Sep 23, 2010 | Gaggenau Ovens
We have an Gaggenau eb 290 oven and the error code F23 shows up - what does this mean? how can we fix it?
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
May 13, 2010 | Gaggenau EB290 Electric Single Oven
How to take the door off a gaggenau eb 290 oven
gaggenau oven EB 378-6 door won't close completely It pops back open 2 inches.
Apr 23, 2010 | Gaggenau EB290 Electric Single Oven
Gaggenau eb 270
No you don't need to remove the oven door to change the cover of the display. You have to remove the whole unit out and remove the top lid. Don't forget to switch off the circuit breaker before doing this and be careful this unit is heavy.
Jul 02, 2008 | Gaggenau EB 270/271 Electric Single Oven
Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk sales@gwhitedist.co.uk
May 04, 2008 | Gaggenau EB 270/271 Electric Single Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
good luck
Nov 20, 2007 | Gaggenau EB 270/271 Electric Single Oven
Gaggenau EB984 Electric Single Oven Logo
333 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
