Question about Philips Televison & Video
How do I hook up my philips 2 way RF Modulator ph61155. I read the directions but I have a cable that comes out of the wall into a cable box. I would like to hook up my dvd player, It is so complicated with a cable box, tv, dvd and rf modulator. I tryed different ways but cannot get the dvd to play. Please help . Thank you so much. I do not have a s-video on the back of my tv. I bought 3 of the rf modulators that I need to hook up for my brother and aunt---so I have to get this figured out. thanks. Marlene
fairlane
  • 50 Answers
SOURCE: connections
Hi If I'm understanding what you have written, the new DVD should hook up exactly the same way your old one did. You connect the red and white cable from the "Audio out" connectors on your new DVD to the "Audio In" connectors on the RF modulator, then connect the Svideo out on the DVD to the Svideo connector on the RF modulator. Then put your TV on channel 3 or 4 depending on what the switch on the modulator is set to, and all should work fine. I would advise you hook your old one back up, then if it works, simply unplug the cables from you old DVD and plug them into the proper jacks on the new one. This eliminates bad cables. If you then get sound, but no picture, the DVD may be set to progressive scan (check manual for procedure take it out of that mode),If you get nothing, then I suspect there is a problem with the new DVD player. The TV/VIDEO switch they mention, would be a switch on the TV or TV remote if you had a newer TV with RCA inputs.....You don't, so disregard that, it does not apply to your TV. You would not need the RF modulator if your TV had that switch. Good Luck!...These things can be a pain, I hope this helps!
Posted on Nov 30, 2006
ttech
  • 139 Answers
SOURCE: connecting VCR/DVD combo
Put the Tv on Channel 3
Posted on Jul 19, 2007
mixmaster
  • 626 Answers
SOURCE: RF Modulator
The RF modulator changes the outputs from RCA (red, white, and yellow) to a Coaxial Cable (COAX).
You connect the DVD players RCA outputs to the RCA Inputs on the RF Modulator, then connect the COAX Output from the RF Modulator to the television.
Best of Luck.
Posted on Oct 23, 2007
SOURCE: installing DVD player/RF Modulator with Star Choice
The RF modulator probably had a red, white, yellow trio of RCA jacks (A/V jacks), a coax jack marked "antenna" and another coax jack marked "TV"
Putting the DVD output to the A/V jacks allowed it to play out to the TV, which couldn't otherwise accept the DVD player.
The satellite box probably has coax and a/v jacks as output. Use the coax as output to the antenna input of the RF modulator, and the A/V jacks of the DVD player to the A/V jacks of the RF modulator. Hopefully the modulator allows the A/V jacks to have priority over the coax input, so that when the DVD plays it "wins"
Posted on Feb 23, 2008
SOURCE: No A/V!
I need help please. i found my atari 8700 in the basement and my old colecovision set too. i want to play them both but do not know what cables/connectors/adapters and such i need.I have the original battery/power supply for each of them. but do not know how to hookup to the tv.please help.
Posted on Oct 10, 2008
How do I reset error code SC548
25685181-yl5nsd0dwyytd1n2wv4v20hl-5-0.jpg OR
Sponsored Link Shop Bulk Wire & Cable
Network, Telephone, Coax & A/V. Quantity Discounts & Same Day Ship!
showmecables.com/Bulk-Cable STEP 1 Purchase the RF modulator at an electronics store. The modulator is used to connect your older television to cable.
STEP 2 Plug the RF modulator in a power outlet near your television. It is best to plug it near the television to allow for easy access.
STEP 3 Connect your television to the RF modulator by inserting the one-prong cord that is on back of your television. Insert the cord in the slot on the modulator that reads, "To TV." On older televisions, this cord is the only cord in the back.
STEP 4 Connect one end of the white one-prong cable to the cable box and the other end in the RF modulator. Connect it into the modulator in the slot the reads, "ANT IN." Usually, the cables are provided by the cable company--the technician uses them upon installation. This particular cable may run along the side of the wall to your cable box.
STEP 5 Turn on the cable box and the television set. Everything should be working properly. On the RF modulator, choose the channel for the television (either channel 3 or 4). The modulator turns on when you plug it in.
May 08, 2015 | Office Equipment & Supplies
I am trying to hook up my Philips 19PR19 (made in 1998) tv to the dish network receiver, it has 3 prongs diff. colors attached and the cable cord is already to go in the wall...I don't see anywhere on the...
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Apr 07, 2010 | Philips 19PR19 19" TV
How do you hook up the dvd player to the tv with a vcr hooked up to the tv
Leave the cable box powered on but disconnected from the TV or VCR. All other components should be disconnected and unplugged, giving clear and easy access to all connections. If components sit in an entertainment unit, make sure all A/V cables can reach the RF modulator and the cable from the modulator can easily reach the television.
  • Step 2 Hookup the first coaxial cable from cable box output, usually labeled "TV," "TV out" or "Out to TV" to the cable "In" on the VCR. Connect the second coaxial cable from the VCR's out to "TV" to the coaxial input on the RF Modulator.
  • Step 3 Connect the third coax cable from the coaxial cable "Out" jack on the RF Modulator to the coax cable "Input" on the television.
  • Step 4 Take one A/V cable, connect the red (right audio channel,) white (left audio channel) and yellow (video) from DVD player's "Output," to the corresponding DVD "inputs" on the RF Modulator. Place components as desired but still disconnected from power. Plug in all power cables including the RF Modulator's into the surge protected outlet strip.
  • Step 5 Make sure the Channel select switch usually found on the back of the VCR and the Channel select switch on the RF Modulator are both set to Channel 3. This channel is used on the television to view your components.
  • Step 6 Turn on the power strip and turn on the TV. Cable reception should come on as usual. Set the TV to Channel 3 and turn on the VCR. With VCR on test it by playing a video tape. The RF Modulator should sense the signal and automatically switch to "VCR."
  • Step 7 Switch off the VCR and with the television still on channel 3, turn on the DVD player. As the RF Modulator senses the DVD player signal and switches to DVD, its welcome screen should be seen on the television. Play a DVD to test and once you're done with the DVD turn it off and the cable should come back on.
  • Jul 15, 2009 | Televison & Video
    I conected the converter box and then took it off it erased my ch
    You will have to get a RF Modulator so that you can hook up converter box and your ps2, your tv is saying progam channels because there is no box hooked up anymore,
    Hope this helps.
    May 05, 2009 | Philips Magnavox TP3285C 32" TV
    Hook up
    Purchased a rf modulator and hooked in to the tuner out to modulator and from modulator to tv that made everything work
    Apr 12, 2008 | Philips Magnavox DVD/VCR Dual Player
    Need directions to install a dch70 box to tv
    dear woolifer ,
    I am not an expert but i hope i can help you..
    is it youmean digital cablebox?
    if it is try this-
    This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
    As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
    1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
    2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
    3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
    4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
    5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
    This should be all you need to get started watching your digital television. In simple terms here is what you did:
    Coaxial from wall to cable box
    Cable box to VCR
    VCR to RF modulator
    DVD player to RF Modulator
    RF modulator to TV
    You will only be able to record what is on channel
    Apr 09, 2008 | Computers & Internet
    Trying to Install
    Do you have the red, white and yellow hookups on the back of your TV????? If you don't then you need to get an RF Modulator. You can buy one at Walmart. Older TVs don't have the red, white and yellow hookups. You hook up the RF modulator with a short cable to the cable outlet on your TV. Then you plug in your DVD player to the RF modulator. You also plug your cable for the TV into the RF modulator. It really is very simple. Directions are included with the RF modulator. You will need a short piece of cable also.
    Feb 04, 2008 | Panasonic DVD-RV41 DVD Player
    X-Box
    You can get the RF adaptor from microsoft, but you cant connect the Xbox directly to any recording device, it is some kind of coppyright protection thing microsoft put in every game system.  you cvould also try getting a $20 video switcher from walmart if You dont want to mess around with more cables
    Jan 08, 2008 | Emerson EWD2203 DVD Player/VCR
    How to hook up portable dvd player to watch on t.v.
    You can use the VCRs video in and audio in to view the DVD player. The VCR will act as the RF modulator. You may have to select the TV/VCR button to select the input. (Sometimes line in or Below channel 2 is the L1 L2 input) The VCR has a built in RF modulator.
    Dec 17, 2007 | Coby TF-DVD7107 Portable DVD Player
    Televison & Video Logo
    64 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
