Question about Logitech V220 Mouse
WHY IS MY BATTERY STUCK - Logitech V220 Mouse
  • 490 Answers
Logitech says to use only non-rechargable batteries in this model. Rechargables can stick due to slight size difference. Also, older alkaline batteries can swell. Hope this helps:)
Posted on Aug 20, 2010
Car has no power absolutely opened the door with the key tried starting the car no sound no light now key is stuck in
Your key is stuck because your battery is dead, try hooking up a battery charger to it, remember to pay attention to the proper battery terminals so you do not damage your battery or your electrical system.
The key is likely stuck due to a solenoid that is designed to keep you from removing the key if the vehicle is not in park, when the battery is dead the car does not know it is in park and therefore locks the ignition tumbler from returning all the way off.
How To Connect Battery Charger
Sep 12, 2015 | 2007 Chevrolet Chevrolet Equinox LT
Can a bad battery cause the key to get stuck in the ignition?
No, a bad battery can not cause this problem, but was the ignition stuck in the on position? That would make the battery go dead. A lock smith might be able to help you.
Sep 20, 2014 | Chevrolet 2005 Chevrolet Cobalt Radio
My battery died. After trying to start my car the key is now stuck in ignition, shifter stuck in park, no brake lights. I charged the battery and only get the cluster lights.
Hi there all the things you explain are and need power to operate, make sure your battery has 12.6 volts or more and try again , if your battery doesn't have that voltage then you will need a new battery, hope this helps
May 14, 2014 | 2007 Chevrolet Impala
Battery stuck
I would remove, or at least loosen the housing screws that hold the saw together. I would guess that it overheated and may have melted the plastic if the battery is stuck in the saw.
May 05, 2014 | Dewalt Drills
2003 range rover hse new battery won't hold charge and key is stuck in ignition
was the key stuck in the ignition before you change the battery? Is it the right key or it a fresh cut key
Dec 27, 2012 | 2003 Land Rover Range Rover
HP Pavilion dv6700 battery stuck
Make sure the battery is in good, then keep applying pressure to the latch.
Mar 29, 2012 | Computers & Internet
Sony t20 battery stuck inside
Open the battery cover, shake the Camera and HIT slowly on the hand by putting the battery side down.
Mar 06, 2012 | Sony Cyber-shot DSC-T20 Digital Camera
Battery drain overnight
Can be a relay stuck. Make sure all the P/W will go up and down as they should. A relay can be stuck in the up position. The window switch can also be stuck. Check the Power Seat to see if a relay is stuck or the switch is defective. Move the seat back and forth, up and down, and recline. If a relay is stuck it will move on it's own. Are you sure the radio is not on all the time? Have you checked all the lights? Under hood, trunk, glove box, courtesy, etc?
Jul 16, 2010 | 2002 Chevrolet Malibu
Battery stuck
The battery has leaked and is a goner. Take your camera to the repair shop and hope it can be repaired. Don't try to take out the battery yourself.
Jun 08, 2010 | Fuji FinePix S9000 Zoom Digital Camera
Screen stuck on battery life indicator
My guess is the battery was just changed? This watch needs to be cleared when the battery is changed. I recommend seeing a watch maker/technician to have the circuit board AC'd.
Sep 20, 2009 | Garmin Forerunner 405 Fitness Watch/GPS...
Logitech V220 Mouse Logo
116 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
