Question about Bosch Dishwashers
Model #SHU5314uc my bosch stays on 2H when turning
Model #SHU5314uc my bosch stays on 2H when turning I first turn it on, it is not a 2h delay, this is with a capital H AND I have read the solution posted on June 27, however the water temperature is very hot, it does run for hours on wash, cannot reset it ALSO we desperately need to find a manual, HELP!!??
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: stays on 2H when turning on
Hi welcome to Fixya. You're right what you're describing is not delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. The wash cycle has exceeded two hours without a temperature increase of the water and therefore the control "thinks" something is wrong. Whether there is or isn't remains to be seen. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. macmarkus :)
Posted on Jun 27, 2010
Stays on 2H when turning on
Jun 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
How do I cancel the delay start? Everytime I turn...
Hi Guest and welcome to Fixya, I don't think what you're describing is the delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. Macmarkus :)
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
Jul 07, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
May 27, 2008 | Bosch 24 in. SHU6802UC / SHU6806UC...
Machine runs for 4 hrs and 2H shows
Problem machine ,replace the control electric
May 21, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Stuck on 2H
My wife got our Bosch diswasher "unstuck" from the 2H position by pressing buttons randomly. Sorry this sounds so serendipitous! Good luck!
Mar 05, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Keeps going back to 2H
Have you tried cleaning out the pressure chamber and transfer pipe??
R
Dec 14, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
Jun 24, 2007 | Bosch SHU5307UC Built-in Dishwasher
Dishwashers Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
