Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
HLN4365W Turn set on and incredibly loud noise comes from behind the TV. It sounds as if it's a motor or something; also the temperature light comes on. We've previously replaced the color wheel and lamp.
  • Maksim May 24, 2008
    Loud noise coming from the back of the TV. Not a fan because I took the back cover off and observed the fan. The sound is not coming from it. It seems to be emanating from the central assembly (the projector). What is it and can it be fixed?
  • Samsung Master
  • 8,617 Answers
That could either be the cooling fan bad or the light engine assembly as they both can exhibit the sympton your describing. Can you haer this sound as soon as the power is pushed or does it take a moment. If its instantly chances are its the fan.
Posted on May 03, 2008
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
Wont turn on loud ossilating humming lamp light blinks for a few minuits then all three lights blink
YOU may have a bad color wheel, it is very common. The wheel will before it fails produce a loud high pitched sound and or a grinding noise.
The wheel turns at 14,000 RPM and they frequently fail.
if the wheel is shattered the set should not allow the lamp to come on (you should be able to look behind the set and see if lamp comes on for even a few seconds)
See attached photo of color wheel used in some of these sets; if it is the problem the internet not only offers them for sale but there are video and written instructions for customer replacement of this part.
If this has told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Samsung DLP HL-P5663W 56" TV
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Ref light bulbs wh-pool GS5SHA
Your refrigerator has two sets of electronic control boards. One is inside and works to adjust temperature and to communicate with the other below and behind the refrigerator. They both have relays that if bad could cause the sounds you hear. It would be ok to pull it away from the wall and open bottom cover and listen to see if the sound is coming from the lower control board. If yes we need to examine the board after unplugging the power to refrigerator. let me know if the board is the reason or if while there you find something different, Thanks, Sea Breeze
May 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Very loud noise whirling sound
Can you tell me where the sound is coming from? Like inside freezer or under refrigerator. Most sounds like you describe come from a fan motor and the fan blades are hitting something. Let me know, Thanks, Sea Breeze
Apr 23, 2009 | Whirlpool ED5FTGX Side by Side...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
No picture, new lamp
Did you reset the hours on the lamp with the menu options on your set? Sometimes, if you do not do that it can mess with the tv performance thinking that its over hours. It needs to be reset to 0 again...
Sep 24, 2007 | Samsung HLN4365W 43" Rear Projection...
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
274 people viewed this question
Henry  Thomas
Henry Thomas
