Question about Hansgrohe 32310821 Talis S Widespread Bath Faucet Brushed Nickel
Just installed 2 sets of Hansgrohe 32310821 Talis S Widespread Bath Faucets Brushed Nickel in a bathroom. Installation looks good but when turning off water using lever, the water doesn't shut down immediately but rather slows & finally stops in 1 to 2 seconds. Is that normal?? Also, I notice once it stops, a drop or two hangs on the end of the spout. Finally, once the water stops, if I remove the aerator, water which is apparently trapped in the spout, pours out for 2 to 3 seconds until it's empty. Again, is this normal? If the above is not normal, is there anything I can do to fix these problems?
  • 2 more comments
  • 1riley1 Aug 21, 2010
    Thanks- thought that might be the case but wanted a second and third opinion before letting go of it!
    I do not disagree with the initial response, but would like another expert's take on the issue!
  • 1riley1 Aug 22, 2010
    Thanks for the confirmation that all is OK!!
    Glad to know that everything is ok- thanks for the prompt responses
  • 43,501 Answers
Yes!! Everything you are observing is perfectly normal...
They are a slower shutoff...this ensures that there is no water hammer...also the water will trap in the faucet...that also is okay and perfectly normal.
Congratulation on your installation... glad it looks good also!!!
heatman101
Posted on Aug 22, 2010
  • 8,197 Answers
All the things that you listed is normal with that faucet. the reason why it does this is the hight neck and the down tube hold watter. When you turn it off the down tube needs to drain the water from it. Do not worry your faucet is not bad.
Good Luck and have a nice day
Posted on Aug 21, 2010
  • Jyackle5
    Jyackle5 Aug 22, 2010
    So my answer was good. If so can you please accept my answer and rerate it as 4 thumbs up.
    Thank you
Hansgrohe 31730001 Focus S Widespread Bath Faucet spout is unstable
If you had a professional install it, they messed-up.
Call them back to re-do the installation.
May 20, 2014 | Hansgrohe 31730001 Focus S Widespread Bath...
How do you remove the Metris S wideset faucet handle?
To remove the handle simply rotate the escutcheon counter clockwise and it will unthread from the fixation on top of the counter. Then the handle will lift off as one unit. You can clean them with CLR to clear up water deposits. If you need further instructions feel free to contact me Hansgrohe Tech 1-800-334-0455 press 2 for Technical and ask for David Scarborough. I'll be happy to help.
Apr 08, 2013 | Hansgrohe 31063821 Brushed Nickel Metris S...
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
Need to replace cartridge on hansgrohe talis high arc faucet
The cartridge should come with instructions on replacement. The part number for the cartridge is 92730000. It is available through your local dealer or online dealer. If you need further help with obtaining the cartridge or installation feel free to give me a call at Hansgrohe. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to help.
Oct 04, 2012 | Hansgrohe 32070821 Talis S Single-Hole...
I have a hansgrohe 06697865 Kitchen faucet with "Spayer" end That drips constantly Where can I buy a kit to repair, and how to manual?
You should contact your hansgrohe customer service hotline found on the installation book. They will help you solve the problem.
Aug 29, 2011 | Hansgrohe 32070821 Talis S Single-Hole...
Santiago institute
You don't desribe the nature of the problem
Here is a link to the installation instructions which inlcudes illustrtaions of the assembly:
http://www.pfisterfaucets.com/www/ImageAssets/mirror/model/bath/santiago/san049-st/31156-0200.pdf
Mar 14, 2011 | Price Pfister T49-ST0K Santiago Widespread...
Cold water runs very slowly, Hot water runs much faster
If this is a new faucet in an old location, you may have a service stop under the sink that the seat washer crumbled on. This happpens sometimes because the seats get brittle in the water then you use them for the first time in years. Check the supply hose first for kinks then if it looks okay, you should check for debris by removing the control handle and removing the cartridge. Do you see any black particles in the cartridge? Carefully open the cold service stop under the sink while using your hand to direct the water into the sink. Is the flow poor or good? If good, the dirt is in the cartridge. If poor, you need to turn the water off and look into the opening the cartridge sits in. Sometimes the opening to the cartridge intake may not be completely drilled. Do the hot and cold openings look the same? IF they both look good, then the obstruction is in the cold hose or in the service stop, though it is more common that it is in the hose. You can remove the hose and try cleating it, but never by inserting anything in it. If it requires that, it is time for a new hose. In that case you should contact hansgrohe for the parts. 800-334-0455 or www.hansgrohe-usa.com for support in USA.
Jan 11, 2011 | Hansgrohe 32070821 Talis S Single-Hole...
Installing TL794DD bathroom faucet
All faucets install easily if you have the proper tools. Answer these questions first: 1. how many holes are their in the surface of your sink? Is there a faucet installed now? If yes, you may only need to remove that faucet and use the same feed lines under the sink to hook up the new one. Take your faucet to the hardware store and ask the plumbing clerk if the hook ups under the sink are different from what your new faucet appears to be compatible with. good luck
Jan 17, 2009 | Toto Clayton W/S BATH Faucet BRUSHED...
Hansgrohe 32310821 Talis S Widespread Bath Faucet Brushed Nickel Logo
141 people viewed this question
Top Hansgrohe Plumbing Experts
Andrew Bugbee
Ian Lulham
Ian Lulham
Level 1 Expert
ray gallant
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
