Question about Samsung Comeback Cell Phone
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully charged ) it still doesn't have any batteries. It remains dead. It HAS to stay plugged into the wallcharger for me too use it. Also, it mysteriously gets very hot when I charge it for a while. When it was hot, I took the battery out. It also had an extremly weak vibration, almost non-existant. The phone itself was hot, along with the battery. I took it to the T-Mobile place, and they told me to switch the battery with my brothers because he has the same phone. When we switched batteries, the same problem with mine happened with his. So, we switched back, went to the T-Mobile place, and they gave me a new battery. The new battery worked for about a day before the same problem symptoms occured. It got hot to the touch when charged, died mysteriously, wouldn't hold a charge, and had very, very weak vibration. When my phone was completly fine, whenever it had a low battery, I could still use it for about 2-3 hours before it died. But now, after the first 'low battery' warning, it died. I went from 2 bars, to 4 bars, to 3 bars, and never once got full no matter how long I had it on the charger. Then when I took it off the charger, the batteries continued to go up even though it wasn't charging. Next, I took out the charger, put it back in after I had turned the phone off, and it started looking like it was charging, even though it was not. So I opened the phone and took out the battery, but the phone continued to look like it was charging! That was scary so I put the battery back in, and started charging it. Keep in mind this is all with my new battery. I've had this phone since December 26th, 2009. Is it faulty? I've read people on here have had similar problems. I haven't since taken it back to the T-Mobile store. It is still under warrenty, and I was considering exchanging it for a new phone. I would just like to see if there is any way I can fix it, without getting a completly new phone. So, the PROBLEMS are : *It gets very hot when I charge it *Won't hold a charge *Very weak Vibration *Has to stay plugged into the wall charger Hope you may be able to fix it. If not, appreciate your help. ~Thank you.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Posted on Aug 29, 2010
Find another way 2 charge it i guess
Posted on Oct 01, 2011
I have a samsung comeback. when i put my phone in the charger it doesnt want to chage. the only way it will charge is if i turn the phone on and off a few times. Does this mean that my phone battery is not...
You need to remove the battery and check it with some other phone. Otherwise check to see if there is a problem with the charger by charging another phone. Then you can find out the probleem is in which device.
Jan 07, 2011 | Samsung Comeback Cell Phone
Samsung t559 comeback is locked & frozen ! helppppp ! christmas present !!! i need a network key and how to unfreeze it, i already called tmobile & at&t and they both said they couldnt do...
I had the same problem, but was able to solve it by removing the memory card and starting it up again. I cycled it three or four times, turning it on and off, then charged the battery, as this had occurred when my battery was too low.
I *think* there may be a compatibility issue with the 8Gb memory card I'm using, as there may have just been too much on it...or not. Anyway, my phone is working fine now. I just won't let it get so low on charge (it turned itself off in the middle of the night!)
Dec 24, 2010 | Samsung Comeback Cell Phone
Need an unlock code for this samsung comeback model SGH-T559
I put my att sim in it and too many attempts. It says phone freeze . Please help. If I go to t moble will they charge any thing? Can I master reset?
Aug 06, 2010 | Samsung Cell Phones
I can not get the battery to charge on my samsung comeback - when I plug it into the charger - nothing happens
Try cleaning the battery and phone terminals. It's very possible that it isn't making a proper connection.
May 21, 2010 | Samsung Comeback Cell Phone
How do you change the font size on the Samsung Comeback
Use the scroll/volume bar on the left hand side WHILE IN a message.
Apr 10, 2010 | Samsung Comeback Cell Phone
My samsung cell phone gives no indication when charging so I donot know whether is charged or not.The problem is the charger or the mobile phone?It indicates only the bar which requires charging but when I...
There are 3 solutions to your problem.
1) You need to replace your phone's battery, or
2) You need to replace your charger. (If you have a car charger, try it to determine if your home charger is the problem) or
3) you need to have the charging plug on your phone repaired; it will need to be sent in for service.
Feb 01, 2010 | Samsung SCH-u340 Cellular Phone
Samsung KP-K3 MP3 Player - Charging battery
wen i first got myn i had the same problem i plugged it and left it plugged in for a couple of hours and it showed there bars and was fine i dont quite no wat i did but i suggest double checking you have plugged it in prople sorry if im no help x
Sep 16, 2007 | Samsung YP-K3 MP3 Player
Samsung Comeback  Cell Phone Logo
1,000 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
