Question about Vacuums
I have mobil model 1208 type:rh-105 code:0550326 imei: 356794/02/124438/7 ididnt make asecurity code for my mobile but now it ask me for security code and i enter the master security code but give me code error
Cannot enter my unlock code
What is the problem? what message do you get when you enter unlock code in your mobile? how many times have you tried to unlock your mobile? if its nokia the unlocking limit is restricted to 5 times..the problem may you would have followed incorrect instructions,if you have left tries then try to get codes with correct instructions from theunlockspot and get your mobile unlocked..if you have no tries left then go for flashing your mobile..
Sep 22, 2011 | Vacuums
Forget my security code
Hi,what is your mobile model? if its nokia then try unlock-free to get security code for your mobile and reset it instantly..
Aug 01, 2011 | Vacuums
I need to unlock my mobile phone
Hi,what is your mobile model? you can unlock your mobile by unlock codes..the safe and best way of unlocking is by unlock codes and my personal request is that don't go for software unlocking because sometimes the software might get corrupted and may your data will be lost due to that,its my bad experience so I went for unlocking by codes from here mobileunlocksolutions and unlocked.you can too try but see to that whether your country and provider is listed..because for some service only codes are available..check with that and if your country's provider is listed then get codes and unlock your blackberry..before unlocking your mobile you can get clear instructions about how to unlock your mobile for that you can visit mobileunlockguide to get step by step instructions..
Jun 17, 2011 | Vacuums
I want to remove my restriction code of Nokia 3110c from t-mobile how can I remove it please help
If your mobile is restricted to particularnetwork you need to unlock your mobile , Unlocking by codes is the safest &best method,you can try here http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ to getunlock codes for your mobile and get it unlocked safely..
Jun 01, 2011 | Vacuums
Unlock code for nokia 6600 please nokia 6600 uk T-Mobile imei: 352956001042800
You can get the Unlock code from service provider and Unlock it..
Apr 26, 2011 | Vacuums
I have put a random security code on my Nokia 2310 mobile Phone. Now i have frogotten the password. Please Solve this problem.
Hi friend,
Try this: Nokia *#7328748263373738# Resets the security code to
default thats 12345
and if that does not work then try using your IMEI in this link to
generate a master code:
http://www.lur.nu/nokia_mastercode/security_code.php
I hope this sorts you out
Apr 09, 2011 | Vacuums
Phone unlock code
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
Do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software...
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If you are talking about the security lock code to enter into the phone then once it is lost nothing can be done except flashing the mobile . Because if anybody can give the security code created then who ever who steals your phone can get into it and get your valuable information.
So as safety precaution to avoid that they have designed it such that if you forget the security lock you have to reset the mobile memory by flashing the mobile at an authorized service center.So while flashing the mobile all the data in the mobile memory will be lost and you can again start using the mobile.
Mar 27, 2011 | Vacuums
My phone is gfive u 909 . iforgot my phone lock code. it is asking the code when i switch on the mobile . please help me.........
my phone is gfive u 909 . iforgot my phone lock code. it is asking the code when i switch on the mobile . please help me......... my email address subhashmishra2010@gamil.com
Feb 09, 2011 | Vacuums
I lost my cell.i want block my tata docomo sim.mob no. is 9030879128
Please call the customer service immediately to deactivate your account. Click the following link to get the correct customer service number, http://www.tatadocomo.com/customer-service.aspx
Jan 20, 2011 | Vacuums
Hi! I am looking for a free unlock code for my Nokia 1661 mobile, from Entel Chile, IEME : 011884008602710. Thanks for your help !!
Dear Bro
I am also facing the same problem, whenever you get the solution please let me know.
Model : 1661-2
RH : 122
IMEI : 356940/03/708328/1
my email ID : asimch_83@yahoo.com
Aug 07, 2010 | Vacuums
Vacuums Logo
65 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
