Question about Fantom Computers & Internet
Two yr old fantom titanium 80g. not being recognized by computer. not even firing up. running windows xp OS.
  • Fantom Master
  • 27,725 Answers
Fisrst replace PSU test all leads that attach to your hard drive including the ones from your motherboard and eltrical+elec extensions make sure they have a secure connection or just replace them with new leads
Posted on Aug 21, 2010
  • steenas Oct 30, 2010
    I have Fantom Drives Titanium 250GB i am not able to formate it i am using XP sp2
    if there any answer for me plz mail me complicated.desire@yahoo.com
Windows all of a sudden does not recognize the 100GB hard drive. Message is that the USB device has failed. Running XP on all of my computers and plugging this drive into any of them fails.
There's a possible that the harddrive is corrupted, or could be the usb cable itself, have you tried connecting a different usb cable for the harddrive? If so and still doesnt work have it covered by the manufacturer of the harddrive
Nov 02, 2010 | Fantom Titanium Hard Drive
I am using Fantom Titanium 250GB External (TFDU25072B) Hard Drive i am not able to formate it i am using Windows XP Sp2 its giving me error " unable to formate " even i am not able to formate it...
The disk-drive inside the enclosure is problematic.
Open the enclosure, to get the model-number and serial-number from the label on the disk-drive.
Then, access Fantom's web-site, to check the warranty-status of the drive. If the warranty still is valid, they will replace it, at minimal cost to you.
If the warranty has expired, purchase a new, compatible, disk-drive, and transplant it into the enclosure, to "resuscitate" your device.
Oct 30, 2010 | Fantom Titanium 250GB External...
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Computer not recogning my hard drive. I've tried both USB ports. Light does come on.
Windows update should fix it.
Go to start, program, windows update.
Run all the updates.
If you have dial up then you need to contact Microsoft for the updates on CD rom.
Dec 21, 2009 | Fantom Titanium USB 2.0 80GB 7200rpm...
I connect my external HDD Fantom fine but then I cant see it?
right click my computer, select manage, click on disk manager, right click the drive and select import foreign volume.
Mar 06, 2009 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
How do you install a fantom drive(titanium 2 firewire usb2.0.)or how do i psave programs to it.
You don't mention what kind of OS you're using - but either Windows, or OS X should see your drive regardless.
Before use:
Windows: Format the drive with NTFS.
Mac: Finder should pop up and ask you if you want to initalize the drive, you can choose 'yes' and continue.
Dec 02, 2008 | Computers & Internet
Fantom Drive problem
Try connecting it to a Windows XP Pro pc. Right click on "My Computer", left click on "Manage". Once the new management console opens, left click on "Disk Management". If the USB drive is recognized by the pc, you will be able to right click on it, and select "Delete Partition". WARNING: YOU ARE DELETING EVERYTHING ON THE DRIVE! Once it's done, right click on the drive again, and select "Create New Partition". Proceed thru the wizard that pops up, and format it. You will have a choice of using FAT32, but, if the partition is larger than 32 GB, it will fail (it's a Windoze limitation), so NTFS is your only choice, unless you use a 3rd party utility, Win98 (supports huge FAT32 partitions, 4 TB, I think), or Linux.(preferred). Good Luck, hopefully everything will work out fine. T-Power
Apr 01, 2008 | Fantom Titanium Hard Drive
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Computers & Internet Logo
132 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
