Question about GE Spacemaker Washer and Dryer Electric Laundry Center
The lint intake grate on the dryer is stuffed full of lint but i can't figure out how to remove it to clean the intake
  • 999 Answers
We usually remove the entire front panel of the dryer but it is quite an undertaking. You might be just as happy to work with a small stiff bristle brush, piece of wire and a vacuum.
Eric
Posted on Aug 20, 2010
Cannot locate lint trap to fit my wsm2420 sazww washer dryer combo ge parts no will not fit
In the Kenmore equivalent, the lint trap is on the back wall of the interior of the dryer. If GE is the same then you'll see two vents at the back inside, one is the intake (where hot air enters), the other is the outtake, which contains a lint trap. You might have mistaken both for nonremovable vents. But one of them is removable. It should have finger holes or something to grab. Just pull it and it will pop out without difficulty. It's probably a two-piece unit (a grate on the dryer side and a screen on the exhaust side, with a space in between for collecting lint), which snaps or slips apart easily, then you can clear the lint, and then snap or slip it back together and just push it back in place in the dryer.
Jul 01, 2010 | GE Spacemaker Washer and Dryer Electric...
Harmony Dryer
WOW.I would recommend not to use dryer until you have someone check this out .Please unplug and do not use .Its possible the ball of lint got caught somewhere in dryers mech and or drive parts ..If you get that removed ,while were there ,Its a good time to vacuum and clean the inside for other lint inside..Get that checked out quick as you need that dryer for winter.....take care
Dec 10, 2007 | GE Profile Harmony DPGT750EC Electric...
How do i clean the lint trap in side the dryer. I can't figure out how to take it apart.
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it, or if the vent itself has finger holes or something that you can grab and pull or slide it open.
In some front loading models the two vents are at the back and both look like nonremovable vents. If that's the case, one actually pulls right out easily. It might then have two parts (the grate on the dryer side and the screen on the exhaust side) that snap or slide apart, with a space between for collecting lint. If that's the case, and you haven't cleared it in a long time, it will be packed full of lint. The two parts snap or slide apart, then you can get at the lint and remove it. Then snap or slide it back together and just push it back securely in place in the dryer.
Jun 13, 2010 | Maytag Atlantis MDE7657BY Electric Dryer
Atf6000fs1.. how do I find and clean out the lint trap so I can change my detergent and get this machine to stop stinking!
Jun 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer stopped working after 2-3 minutes
Go out and buy you a duct cleaner. It looks like a dome shaped broom. Clean your duct from the outside and if you can from the inside. Also if you use fabric softener sheets, clean your lint filter with soap and water periodically (every 3 months would be optimal) to remove the clear residue the dryer sheets can leave behind.
Good Luck!
Apr 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer seem to take to long drying
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes are drying slowly. Moisture is leaking
I also recently had the same kind of problem.
I took the front off the dryer, and the lint collector, past the screen, was FULL of lint, sand and dirt. Imagine balling up a large tshirt and stuffing it in there. That's how full!
I'd definately look at how to clean out the lint and exhaust lines as well as possible. That wet air has to be able to get out.
Feb 17, 2009 | Maytag HYE3658AY Electric Dryer
Back heating grate inside dryer has become dark like it's burnt
I used Bartender's Friend. You can find it at Home Depot. Its best to put it on a sponge, rub it on and let it set for about 5. Then scrub with a steel pot cleaner or copper one. It hard to do since the grid is in the back of the dryer but it came off!! Basically, clean it like you would a burnt pot or pan with the Bartender's Friend.
Sep 24, 2008 | KitchenAid KEYS850LQ Electric Dryer
Auto dry not working
If there is a dryness sensor, it will be just inside the door, on the bottom right. You can clean the sensor by rubbing the metal bars with a scrubbing pad. This will remove any wax buildup from fabric softeners.
Possible reasons your clothes may still come out wet:
1. The dryer isn't tumbling the clothes.
2. The dryer isn't heating.
3. The airflow is restricted.
From your description, the third seems most likely. If your machine is the one pictured above, inside the dryer door is a plastic grate over the lint screen. Remove the lint screen. Remove the two screws on this grate (Phillips.) Use a vacuum cleaner with a crevice tool to get out as much lint as possible. Be careful to not shove any lint or debris further down into the blower wheel.
Lint can also clog up in the vent pipe. This pipe should be cleaned or replaced anually. Also, check the exhaust vent on the side of the house.
Mar 07, 2008 | Frigidaire GLGR341AS Gas Dryer
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
364 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
