Question about Garden
Hi...I have a new stainless Weber E320 natural gas grill and the starter will not ignite the burner....what should I do?
  • 999 Answers
Make sure the electrode is positioned properly to get a spark. Check the operation of the ignitor and/or(batteries?) If all else fails there should be a 800 number in your manual. You indicated it was new so any parts should be replaced in warranty.
Eric
Posted on Aug 20, 2010
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
I think I need a new crossover ignition system for a Genesis 320 natural gas grill, where can I get one? I cannot find the correct one on your website.
Nancy, we don't have any parts on the FixYa website. But, if you're referring to to the crossover burner, that lights the last burner, you can find it at the following link under "tubing". http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/weber-tubing.html
Hope this helps you and Happy Grilling. Thanks for choosing FixYa.
Aug 02, 2011 | Weber Genesis Silver B Grill
I cannot find a supplier who can provide an LP to nat gas conversion kit for my 4 burner grill made under the name: Ducane, model # 30400040. Can you assist? Marlin
Perhaps, the reason you can't find the fuel conversion parts is that they are not convertible from one fuel type to another. Ducane/Weber makes both an LP model and a Natural Gas model of your grill, but no conversion kits. Because, as the Owners Manual states "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty."
http://help.weber.com/manuals/ducane/2009%20Manuals%20pdf/Affinity_3400_4400_NG_OwnersManual_27010342_061008.pdf
Certainly, you could attempt it, Marlin . But it's not the wise thing to do.
I know this wasn't the answer you may have wanted, but I hope it helps you.
May 06, 2011 | Ducane 30400040 Stainless Steel Grill
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
I have weber q200 grill and only 2/3rds of the burner will light. what is causing this?
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 08, 2010 | Weber Q Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 20, 2010 | Weber Q300 Grill
Convert from lp to natural gas
You need to change the burner orifices. These screw on the back side of the gas valves, under the grill, where they feed into the burner tubes. There are conversion kits available. Just call customer service at 1-800-446-1071
Jan 30, 2010 | Weber S-620 Stainless Steel
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
