P=160 r=30 s=11000 eff=1 - Heating & Cooling
<span class="sectionbodybold">P= 160 R= 30 S= 11,000 Eff= 1 </span>
Posted on Aug 21, 2010
Effects not working on Behringer PMP4000 monitor
Normally, on mixers, Effects do NOT go to Monitors.
What you have to do is
(check if there is a control for "EFF to MON" before)....
*Make a cable bridge from EFF OUT to any channel of your inputs.
*Now you can send the EFX to monitors as you would any signal.
Be mostly happy....
May 16, 2015 | Behringer Pmp4000 Europower 1600-watt...
I live in Benton Illinois 62812 I own a lot and want to put a double wide trailer on it can I
Mobile Home - conventional mobile home designed for permanent habitation and constructed for transportation on wheels. Does not include a mobile home served by individual utilities and resting on a permanent foundation with wheels, tongue and hitch permanently removed.
PUBLIC SAFETY
(430 ILCS 120/) Illinois Manufactured Home Installers Act.
(430 ILCS 120/1)
Sec. 1. Short title. This Act shall be known and may be cited as the Illinois Manufactured Home Installers Act.
(Source: P.A. 89-522, eff. 7-19-96.)
(430 ILCS 120/5)
Sec. 5. Legislative findings. The Illinois General Assembly finds that manufactured homes are a viable housing resource for many citizens in Illinois. The General Assembly also finds that improperly installed manufactured homes can impair the public health and safety. Therefore, it is in the public interest that manufactured homes are properly installed by responsible and qualified individuals.
(430 ILCS 120/10)
Sec. 10. Guidelines for manufactured home installers.Within one year after the effective date of this Act, the Illinois Department of Public Health shall work with all interested parties to publish guidelines for persons who install manufactured homes in this State. These guidelines may include in whole or in part any national guidelines or standards for persons who install manufactured homes.
(430 ILCS 120/15)
Sec. 15. Accredited manufactured homes installer courses.Within one year after the effective date of this Act, the Illinois Department of Public Health shall work with all interested parties to propose rules for the accreditation of courses for persons installing manufactured homes in Illinois. The courses shall provide instruction on how to install a manufactured home to the specifications of the manufacturer, review the installer guidelines, and test the written and practical installation skills of the individual installer.
(430 ILCS 120/20)
Sec. 20. Notice to buyers. A person selling a manufactured home one year after the effective date of this Act shall encourage the buyer of that home to use an installer who has successfully completed a manufactured home installer course accredited by the Illinois Department of Public Health. The seller shall also inform the buyer that failure to properly install the home may invalidate any implied or expressed warranties concerning the home.
(430 ILCS 120/99)
Sec. 99. Effective date. This Act takes effect June 1, 1996.
(Source: P.A. 89-522, eff. 7-19-96.) 430 ILCS 120 1
Illinois Pro Bono Regulation Legislation and Use of Mobile Homes
Apr 01, 2015 | Cars & Trucks
Stumble @ 30-40 MPH under ligh acceleration
Problem sometimes is with cheap parts they are bad.Good wires,good plugs,good coils.
May 05, 2013 | 2004 Mitsubishi Endeavor
Igniter is not working
1) Copy following link for igniter troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#igniter
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 20, 2012 | A.O. Smith BTH-500A Commercial Tank Type...
I have a whirlpool duet washer/dryer. Large capacity i think. When I wash my husbands work clothes (dirt, grease, etc) I'm not sure if they are getting clean. They come out smelling just like they...
Hello
Could be the wash soap your using.You need to use high eff soap with this washer.
Tide makes a high eff soap,you will see it on the lable marked high eff.
Also check your drain line for any debris or blockage and remove.
Aug 01, 2011 | Whirlpool Washing Machines
Buzzing sound when turned on
UNFORTUNATELY THIS IS A DEAD GIVEAWAY OF A BAD MOTOR
HOWEVER SOME GOOD MAY COME OF IT YOU MIGHT WANT TO RESEARCH PRICES FOR THE NEWER ENEGRY EFF/ ADJUSTABLE MOTORS WHICH CAN TRULY SAVE $100'S EVERY YEAR
HOPE I HELP A LITTLE--CHARLIE --POOL PROS
Sep 01, 2010 | Pentair Whisperflo 1 Hp Pool Pump Wf-24...
Check engine light p0300, p0420 & mtv solenoid makes noise
P0300
1.ignition system fault spark plug ign wire coil.
2.vacuum leak, inj fault.
3.high or low fuel pressure.
P0420
1.catylist eff low bank1- cat can be defective.
2.eng misfire, vacuum leak.
3.engine oil leak into the exhaust valve guide seals.
as for the warranty i dont know.
May 04, 2010 | 2005 Chrysler Pacifica
My heat won't blow through the vents. The furnace ignites itself but it cuts off after a minute. I've sanded the flame sensor but it still won't work. What can I do now? I just want heat in this blizzard!
If the ignitor glows and the burners lite and then shut off, the flame sensor was the best place you could
start at.
If this is a reg gas furnace or a High EFF. furnace make sure your gas meter is not covered up with
snow.
Turn your thermostat all the way up, if the furnace
does this 3 times in a row-then it should go into
a lock-out mode. Has it done that?
On reg. gas furnace make sure your chimney is
not obstructed where it connects to the furnace.
If it is a High EFF furnace make sure the pvc exhaust
vent is actually venting. It should also have a pvc intake air vent make sure that is not clogged.
If it is a high eff furnace, turn unit off and remove
the door that covers the ignitor and burners. This is
usually a interior door with a sight glass in it. Turn
furnace on, if it lights and stays operating, then you have a problem with the intake vent
Feb 11, 2010 | Heating & Cooling
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Overall review
Fuel Eff : Fuel Economy 65 kmpl Fuel Capacity 10.3 litre Fuel Reserve 1.8 litre fuel Type Petrol. Engine parameters: Engine Type 4-Stroke SingleCylinder AirCooled OHC, Displacement 97.2 cc, Compression Ratio 8.8:1, Maximum Power 7.7@7500 BHP@RPM, Maximum Torque 7.55@6000 Nm@rpm, Bore 50 mm, stroke 49.5 mm, Ignition CDI. for details look up http://www.infibeam.com/SDP.action?catal...,,,
Nov 10, 2008 | 2006 Hero Honda Splendor+
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
