Question about Ovens
I had a power cut and it only lasted 8 mins my cooker works top oven works but the main oven doesnt how do i work it as the fan and light works but oven do not thank you
  • Ovens Expert
  • 414 Answers
If you have had a power failure, you may find that the clock has reset. If the clock has an auto setting this will be linked to the main oven only and therefore the clock will need to set to manual for the oven to work. The alternative is that the oven element has blown and this is what tripped your power, in which case you will need to replace the element. Hopefully, the first scenario is correct and will be a lot cheaper.
All the best, pls leave feedback or reply for further assistance with make and model number.
Posted on Aug 21, 2010
I have a eob6630 Electrolux cooker. Top element / bottom and work ok. But oven cuts out approx 20 mins when cookin. Then switches off. But comes back on when cools. Approx 20 mins. Can anyone advise about...
From my experience the most common reason for this failure is a thermal switch for cooling fan. It is located on the upper side between the wiring and its function is to switch off the cooling fan when the temperature drops even though the oven is already turned off. If the cooling fan does not work then it will increase the temperature on the cabinet and the main temperature limiter will switch off the oven.
Dado
Jul 01, 2014 | Electrolux Ovens
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Main oven no longer heats up, fan is working but no heat
This is most likely the main oven heating element that is defective.
They do last between 4 - 8 years before burning out - sometimes longer.
Check your make and model and look online for replacements.
Fitting is fairly straight forward DIY - just pull the fuse for the cooker first, and check it is off before opening up.
The only other fault it can be is the thermostat switch. You should be able to test this with a multi-meter when checking the oven element.
Remove power and observe standard safety precautions before testing.
Feb 20, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Electrolux Oven EOB6630, similar to above
Hi, I've had a similar problem with my electrolux EOB4633. I've replaced the "thermal cut out unit" and it's working now. Basically this unit switches on the outer casing fan ( on top in my oven ) to keep the casing from overheating. When the thermal cut out doesn't work it fails to switch on the fan and the casing overheats, the oven then cuts out completely until it has cooled down and the cycle starts again.
The bit to be replaced ( part no 8996619267611 ) is located on top of the oven, under the outer cover, just behind the timer & selector switch. It's a small ( 1inch long ) silicon sleeve with 4 wires coming out of it, just unplug the wires and replace it with the new one ( unplug/disconnect the power to the oven, or switch of the power at the mains switch first ), then remove the oven outer top cover ( all you need is a screwdriver ). You'll see the offending unit, probably tie wrapped to one of the wire bundles, quite easily - mine was blackened and charred.
Jan 29, 2008 | Electrolux EOB6636X Ultrafan Electric...
Oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Dec 19, 2006 | Electrolux EOB6632 Electric Single Oven
Ovens Logo
155 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
