Question about Haier 65-Pint Dehumidifier
User Manual has no guidelines.
Just what should the humidity level be set at in a basement, and how to set to run in auto? Thanks for any help....L E
  • Anonymous May 09, 2008
    Just plugged it in NEW. Temperature states it is 66 and humidity is at 63%
    I can't get the humidity down button to take it down to 50%
    When I push it, all it says is ON in red! What gives?
When you first turn on the unit it is set to 40% humidity which is the lowest the unit will accept. You can only move the up arrow from that point. The 63 you are seeing is the actual humidity. If you want 50% youo need to press up arrow till 50 is displayed. The manual for this unit is terrible. Just leave it as it is and it will attempt to bring it down to 40%. 30 to 50 is the recommended humidity range.
Posted on Jun 23, 2008
  • 828 Answers
Normal set point on humidity control should be about 50% or half way on the dial. This same switch will cycle it on when the humidity is close to 50% and also shut it off . This is your automatic. The humidifier will also shut off when the collector bucket nears full, unless you set it to drain from the connection with a hose to a drain.
Posted on May 05, 2008
My Danby DDR606 runs hot. I have the hose direct drain into the water drain in my basement. What is causing it to get hot?
It's probably running continuously.
If so, its either set that way (or for too low humidity) or the unit is undersized for the area / humidity level. Check for sources of humidity that can be controlled otherwise, or add another unit.
Please rate 4 stars if this is helpful. Thanks and good luck!
Aug 18, 2017 | Danby Dehumidifiers
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
Just bought a dehumidifier in the ground level of a high ranch I am very frustrated because I dump the water every day I waas told to keep the humidity at 45- 50 but it keeps on going up This seems to be a...
It isn't necessary you run it 24 hours a day. You can set it to be on for 2 or 4 hour intervals and then it Turns OFF. However, I am a bit concerned that you have the humidity extraction level set a bit high for a basement application. 50% is more than most basements need to be. Lowering it to 35%, will remove more humidity and eventually will run for shorter periods of time. It takes several days of operation for the dehumidifier to get the humidity under control.
If you have a floor drain in your basement, you can use a hose to daring the water, rather than having to empty the bucket daily (which is not that unusual). See your Owner's Manual on how to connect a 48" length of garden hose to the dehumidifier.
I hope this helped you & thanks for choosing FixYa.
Sep 17, 2011 | Friedrich Dehumidifiers
My husband saids run the dehumifier on low setting to take out dampness in the basement? I said no, run the dehumifier on higher setting like 50 or 60 to take more water out of he basement? What should...
Actually, your husband is correct. The settings reflect the amount of humidity you want to remain in the house. I really don't think you want to leave 50 to 60% humidity in the house.
35% removes the greatest amount of humidity.
Hope this helped answer your question and thanks for choosing FixYa.
Sep 16, 2011 | Haier HDN655E Dehumidifier
How do I set the humidity % on my dehumidifier? I lost the User Manual and the unit is not collecting water after running for hours. Make: Airworks - Model: A1DMDA10AG
If you have an LED screen on your unit, lower (arrow down) the humidity extraction level to 35 - 40%. If you have an analog unit, turn the humidity extraction knob to Maximum (which should be clockwise).
Hope this helped you and thanks for choosing FixYa.
Aug 15, 2011 | Dehumidifiers
Dehumidifier is running but noy collecting any water from a very admp basement
Shannon - The basic things that cause this problem are easy to troubleshoot and solve.
1. The humidity extraction level is set to HIGH. Lower it to 35% or less.
2. The air intake filter is dirty or clogged. Remove and clean the filter following the Owner's Manual's instructions on "How to clean the filter."
3. Not enough clear air space around the unit. Maintain a minimum of 12" Clear Air Space on all 4-sides of the unit.
4. The ambient air temperature at floor level is between 40 & 60 degrees F. Since the unit is a basement, the air temperature at the floor level is colder than the air temperature at chest level. Place the unit on a sturdy table or counter, that can handle the weight of the unit, plus a full tank of water.
Hope this helps you to troubleshoot and solve the problem. Please let me know, Shannon. Thanks.
Jun 08, 2011 | Kenmore Dehumidifiers
I have West ponte Mdf 65 Ae BA8 dehumidifier 1 year old. Filter is clean. It worked last summer but now after the winter it is running fine but no water is comming in the bucket eventhough basement is...
You may have the humidity/moisture level set to high. Try lowering it to 35%. Or if you don't have a LED Screen on your unit, turn it to maximum.
In addition, most dehumidifiers don't work well if the air temperature is between 40 & 60 degrees F. Keep in mind, the temperature at floor level in a basement is colder that the air temperature at chest high level. Raising the unit up, off the floor on something sturdy enough to handle the weight (with a full tank of water) and the vibration, may help.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Dehumidifiers
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
New unit, try using in basement. nothing happen, should humidity settings be high or low? Dose humidity level be high? In the bucket whats the plastic cup about? do something alow water to enter bucket?
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Apr 15, 2011 | Haier DE65EJ Dehumidifier
I recently picked up a dehumidifier with no manual and digital settings.......... my question is this, I want it so it dries out the basment as much as possible, so do I set it to the 20% setting or the 70...
The lower the setting the longer the run time, so if you set this unit to 20%, it should in essence run constantly, as it would be quite difficult to pull a basement down to such a low humidity level. Hope this helps.
May 06, 2010 | Dehumidifiers
Haier 65-Pint Dehumidifier Logo
608 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Bill Long
Jim Thurston
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
