Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My TV is strobbing it plays but the picture blinks Thanks Gary
  • RCA Master
  • 8,617 Answers
Sounds like the HV splitter or flyback transformr has an issue.
Posted on Aug 20, 2010
My rca 32 inch lcd tv has a strob affects. What can I do. It every channel and it is all the time.
Do you get the same effect if you play a DVD through your set? If not, then the problem is perhaps with your aerial or your receiver if it is separate from your TV.
Jan 05, 2016 | RCA Televison & Video
The picture was fine when tv was linked to the BT tv kit. Now it's connected to the digitak aerial the picture has a pink/red tinge. How can I correct this? Thanks Gary L
Hi Gary. Not sure if this will be of any help, but have you tried connecting a DVD player and seeing if that is still colour tinged. It may be possible that your TV may have developed a fault and coincided with changing your aerial and there is in fact nothing wrong with the new aerial. I hope I'm wrong. If you are connecting through a different signal input socket, that may also be faulty or dirty. Basically, until someone can come up with a possible reason and fix, it may be worth ruling out other causes for the problems. Regards, Steve.
Oct 13, 2015 | Televison & Video
Screen strobbing
you have to check for a loose contact at the main board then you can check the flyback transformer which have leak. the the high voltage is arching at the picture tube.
Feb 17, 2013 | RCA F32650 32" TV
I had to replace my lamp bulb in my mitsubishi wd-60638 tv and now i have a picture again but it is fickering and greenish tint to the screen
If you tried a cheap bulb then that might be the problem as some of the bulb carrage may not be complete4lyto spec. I had one that was close but there was a gap between bulb and where it fits. I went with a bulb dealer that had I believe a 1 year warrante and I have had no problems. I had a 73838 tv set.
Jul 26, 2017 | Mitsubishi WD-60638 DLP TV
Beko 32 inch lcd tv sound but no picture repair or buy new
i have a 32 inch beko tv the freeview has stopped working and now i can only get annalog channels. can any1 tell me how i can fix the freeview problem ..thanks gary
Aug 08, 2010 | Televison & Video
There are 5 blinks to my RCA big screen TV. The lamp is new, and the picture plays for about 3 min. then goes dark with sound for 3 min.
Hi
Thanks for using FixYa. Assuming that they are blinking green 5 times you need to open the lamp door, make sure switch is in tied down position, take the lamp out and put it back in, close the door and see if the problem still exists then please revert with the model no# of the TV and also let me know which light is it that blinks 5 times so that I can further assist you. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 06, 2010 | Televison & Video
Mitsubishi ws 65819
Ur power board ic converter it dead.
Ur Convergence board is bad going to die to.
Both must change.
Aug 15, 2009 | Mitsubishi WS-65819 TV
There is a black square in the upper right corner of tv
This my be your PIP ( picture in picture). check yor menu to see if it is on.
May 29, 2009 | Panasonic (TH-50PZ700U) Television
Can't initialize @ start up lights strob and display reads c 1?
after you turn on, can you make copies, does the unit creates any grinding noise, please let me know.
Jan 17, 2009 | HP OfficeJet 7110 All-In-One Thermal...
Red light blinking rapidly...no picture
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Sep 25, 2007 | JVC HD-56G886 56" Rear Projection HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
