Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Trying to install a brush assemby part number 188-052 and am not quite sure how--is there an assembly manual available? (Minn Kota Endura 30).
  • 157 Answers
SOURCE: Minn Kota 30 transom mount motor magnets fell out during service
Hello Bob, Contact www.minnkotamotors.com/index.asp choose ext#406 ask for Dave. He is a good guy. Merry Christmas.
Posted on Dec 05, 2008
SOURCE: I have a Minn Kota Endura 30, transom mount.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
Posted on Apr 17, 2009
SOURCE: minn kota endura 30 repair
The top section will pop off when the six screws are removed. It might just be dirty and sticking.
Posted on May 06, 2009
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
Posted on May 13, 2009
SOURCE: how do I remove the composite shaft from the motor housing
I just replaced the shaft (composite) on my Endura 34 today. First, remove the crossbolt that attaches the control head to the top of the shaft. Second, remove the top cover of the control head. Third, make note of the wire connections within the control head (take a picture) and then unplug the red, yellow, white and black wires...no need to unplug the main 6 guage red and black power wires. Fourth, with the wires unplugged, pull the shaft with motor housing attached through the transom mount assembly. Fifth, immobilize the motor housing (gently vice?) and heat the socket in which the shaft screws into motor housing. Do not overheat, only use enough heat to soften factory sealant making unscrewing shaft possible. Sixth, reassemble in reverse order.
Notes: Do not use a pipe wrench as this will crush the composite shaft, either old or new. Apply thread sealant prior to installing new shaft (I used Permatex Thread Sealant/Formagasket). Ensure crossbolt hole on top of shaft aligns with motor housing below.
Posted on Jun 17, 2009
What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Where can I download an owner's manual for an Endura 30 trolling motor
I have an Endura 30 also and haven't been able to find an owner's manual or a service manual. I did find a schematic which is almost as good as a service manual. It gives an exploded view of the entire assembly as well as names and part numbers for each part. It's all I needed to order parts & repair mine. It is even done in such a way as to illustrate how it comes apart and goes together.
Here's the link: http://www.mikesreelrepair.com/schematics/displayimage.php?pos=-4777
Sep 11, 2010 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Trolling Motor specs
call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
Got the Endura 30 from my wife for Christmas. Hooked it to the boat,a 12 foot MirroCraft and tested with battery and overall check, looks good so far. First time in the water on Monday, May 24, made it 30...
have you called the dealer or returned to the store your wife bought it from. they should be the ones to warrenty the motor. if she bought it used then you need to buy the necessary parts from a suitable store and move on. minn kota is a good company and they make a good product. i do understand your frustration. you might ask for a manager at minn kota if your wife brought it new and she if you can successfully get a better answer on an appeal. good luck.
May 28, 2010 | Minn Kota Endura 30 Freshwater Transom...
Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
Hi!
Here is a schematic for your motor:
Endura 30
It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
Best of luck!
Mike
Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
I need a truster speed for a Minn Kota Endura 46
Hi!
Here is a scchematic with part numbers and service center listing as well:
Endura 46
Best of luck!
Mike
Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn kota endura 30 repair
Apr 12, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
182 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
