Question about Garden
I need the part# for rebuild kit for carb. on a craftsman lawnmower- the model # on the engine is 143.996000. can you help? thanks, gordon
  • 4,323 Answers
Hi
The part number for rebuild kit is 632760B, while the substitution part # is 49-019 . Please check the schematic for details---
Craftsman Lawnmover Parts Link
You can also buy the parts from above link. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 20, 2010
How to fix lawnmower
what wrong with it if it wont start check for spark at plug if works try squrting starter flood into carb if tries to start rebuild carberator tecuseh engines are bad about clogged up carb with dirt
Aug 16, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Carborator gummed up
You can try contacting Sears and see if they can track one down. It doesn't show one on searspartsdirect so you might need to actually get the numbers off the carb itself.
You can search "Snow blower parts" and then one by one try the different parts companies with your model number to see if someone has one.
There is a very helpful forum, snowblowerforum dot com that you can post the question on and might get someone with a similar model or more craftsman knowledge who might know where to get one.
If you get the numbers off the carb I'd also check out ebay as at times the carbs are so cheap rebuilding them doesn't make $$$ sense.
Nov 08, 2013 | Garden
Need a diagram for a craftsman model 79103
Go to any small enj / lawnmower shop and they can help you as far as ordering carb parts, doesn't have to be
Sears. Prob has a zama carb, you can go to zama.com and look up your own carb kit # and then proceed to your local dealer, Not lowes or menards,walmart, has to be a true repair shop, I hope This helps you, also your carb will have a stamped number on it and that is your reference number
Oct 03, 2011 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 4 cycle engine model 143.814032. I can start the engine and it will run for about 30 seconds and stop. I have check air filter, choke,new gas new plugs . I have taped on the bottom...
Clean your carb for starters. Sounds like you have a fouled carb inside. If this is a trimmer you might need to just buy a carb rebuild kit and start fresh. Good Luck...
Aug 31, 2011 | Craftsman Garden
Briggs and stratton 5.5 lawnmower starts and suddenly stops. carborator flooding
I suggest that you start with the carb issue. Flooding is an issue with the inlet valve and float system. Get a rebuild kit and rebuild the carb. My bet is the unit will work correctly after that.
Apr 03, 2011 | Craftsman Garden
Craftsman 25cc 2-Cycle Blower/Vac only runs with choke on
Your engine is starving for fuel. Tyipically rebuilding the carb is a quick fix. If you can remove the carb and look at the face of it, you should see a brand and model #. Use this to purchase a carb kit with the needle and metering diaphram or have a mechanic rebuild the carb.
Oct 05, 2010 | Craftsman Garden
Craftsman Incredi-Pull Weedwhacker Model 316.791860. Upon starting, I am unable to keep it running by use of the throttle. I have to let it run on idle which is very high, and trim without using the lever....
Some will say you just need to clean the carburetor but if you put a rebuild kit in it or a diaghram kit (cheaper) you will be cleaning it anyway. This points to a fuel delivery problem and it seems that the mylar fuel pump diaghram inside has stiffened and is no longer functional. Ethanol in the gas and time cause this problem. This usually causes lack of acceleration. A plain diaghram kit may fix this ill if nothing else is wrong. Get your Carb type and model (on carb body) and reference them here for rebuild or diaghram kits!
http://www.m-and-d.com/zama_carburetor.html
Aug 31, 2010 | Craftsman Garden
Engine seems to be flooding out. I have spark but if you take the plug out it is soaked with gas.
if it's flooding out try starting it without using the choke. if it still floods then the float in the carb is stuck open and you will need to remove and rebuild the carb. they sell complete carb kits for all makes of engines..good luck
Mar 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ariens ST724 carb issue
You'll need the model and serial number and also the carb will be helpful, if you take that info and the carb to your local lawnmower shop they will be able to supply you with the right kit.
Dec 31, 2008 | Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
