Question about Bosch SHU9915UC Dishwasher
Where can I get the diagram of pump etc for my bosch dishwasher SHU 9915 UC/U11
  • kalingpon458 Aug 20, 2010
    My Email is kalingpon@gmail.com. Thanks. The problem I'm having is not being able to drain the water. I've checked all pipes etc and see no blockage. Should I go straight to checking the pump? How do I get to it? That is why I'm hoping the schematic will help.
    Thank you,
  • Bosch Master
  • 2,605 Answers
Hi, thank you for choosing FixYa and accepting my assistance.
To supply you with the "pdf" technicians repair manual I will need you to post your email address to me so I can send it as an attachment.
I would simply attach it here, but FixYa will not allow files more than 150KB in size.
It will be a repair manual for all Bosch "SHI", "SHU" and "SHV" dishwasher`s and approximately 5MB in size just to be completely clear.
If there is something not referred to in the manual you`d like to ask please feel free to ask me and I`ll try to assist you in that regard.
I`ll watch for your reply post and send the "pdf" asap.
Thank`s again.
macmarkus :)
Posted on Aug 20, 2010
  • 1 more comment
  • Mark MacDonald
    Mark MacDonald Aug 20, 2010
    Hello again.
    The issue most likely lyes in the pump, I would agree. It is accessable through the toe panel/kick plate.
    Once removed it will be directly in fornt to your left. It twist off the main sump assembly, and much easier if the small drain hose in front of the sump is removed first.
    That info will be fairly well laid out in the manual also, and likely better than I can explain it.
    **make sure you disconnect any power before servicing the unit though...safety first of course**
    Let me know how it goes and I`ll try and assist you if needed of course.
    Good luck.
    macmarkus :)
  • Mark MacDonald
    Mark MacDonald Aug 25, 2010
    Hi again,
    Just wanted to follow-up from our last interaction,. I sent you the info for your dishwasher.
    How did you make out ? Did you resolve your problem with the guide I sent you ?
    Let me know or accept the solution I provided regarding the pump issue and supplying the manual.
    Thank's again for choosing FixYa.
    Macmarkus :)
  • kalingpon458 Aug 25, 2010
    Hi Mr Macmarkus - I'm waiting for the part to arrive. Hopefully, by tomorrow a.m (Pacific Time), I'll be able to instal and see if it works.
    Incidentally, even though we don't use our dishwsher often maybe no more than 30 times a year - it's just my wife and I so we don't want to have that many dishes lying around - it is a 10 year old machine. I'm trying to figure out when you replace it. Any suggestions please?
Dear Sirs, I have a client with a Bosch dishwasher that is leaving a film on all of the dishes. the water valve is working and the drain pump is working. Apparently this has just started. Any ideas?...
Hello
Welcome to FixYa.
Can you provide a model number of your Bosch dishwasher ?
Depending on the model ( i.e. SHU, SHV, SHE, SHX followed by several caricatures etc. ) it can be several possibilities so I`ll hold off generalizing and instead try and speak specific about your model.
Regards,
Macmarkus :)
Sep 23, 2010 | Bosch Dishwashers
I have a built-in Bosch dishwasher SHU 4302 UC. It no longer drains the water out at the end of all the cycles. I have tried everything mentioned in the booklet (make sure water is hot, use the jet-dry...
The problem is a solenoid on the bottom of the unit. It is a small black cylinder next to the pump. It operates the valve that changes to the drain cycle. You can probably order one from Bosch
Aug 18, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Impeller is going bad. What will cost to fix on a Bosch shu 9990
Hello there
Normally you will want to get the impeller kit for this it will include the seal for the impeller
Drain & Wash Impeller Kit - Comes with drain & wash impeller, pump seal, chopper, gaskets, screw and instruction sheet.
Part Number: AP3115180
Our Price: $29.00
this is a quote from parts select.com
and is usually a fairly normal price
ok hope this is very helpful for you
Best regards Mike
Jan 06, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Water does not get pumped out of dishwasher
I have had this problem a few times. For me all I had to do was unscrew the vent/overshow knob on the sink and clean out the vent. Because the vent is clogged, it does not allow the water to flow out. Clean out the debri and screw the vent cap back on- should work fine.
Aug 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Our Bosch SHU 4300 dishwasher does not drain fully
There is a recall on the control board of many of these models, butyour problem is likely not related. A sticking impeller indicates that the pump may be failing, but you are welcome to try my guide to help. It is here. Thanks!
Jun 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
SHU 9915 won't drain. Removed filter, and turned impeller. Does it turn both ways? Do i do a practice wash or is there a test to see if it draining? thanks
It can be the pump or the back-flow valve
The best way is to test it by putting power on the pump and see if it works.
if it rotates it is the back-flow valve
HERE is the drawing and parts list
Make sure it is for the right machine as there are more of that model ( you can enter it in the model section to see for yourself0
Nov 30, 2008 | Bosch Dishwashers
BOSH SHU 3030 Dishwasher timer
This weblink will help you
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwaher shu 4322 uc/u12
remove outer door skin and kick plate at base pump will be on view turn off power look carefully at pump you will see a lever you have to cut away a small section of plastic on lever to be able to push it inwards pump then twists off anticlockwise is a bayonet fitting like a light bulb.
hope this helps
Jan 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9915UC Dishwasher Logo
99 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
