Question about Nikon COOLPIX S570 Digital Camera
My sister dropped my camera and the lens is half out and it says lens error. What do I do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Try the procedure in this tip.
Posted on Jun 12, 2012
SOURCE: Lens error
same happened with mine. some people pushed it back in or used a thin driver to jam in in between the side with the bigger gap.
try it while you press the on button.
Mine is still jammed so I'm going to either get it replaced but try disassembling it first.
Posted on Dec 27, 2008
SOURCE: dropped camera and now lens will not move
This worked for my camera, Nikon Coolpix L10!! I'm so happy I didn't go out and buy another camera!!!
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Kathy
Posted on Jan 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: lens error
You can send this to manufacture and they will repair it for $50.
Unless you get lucky enough to find parts on ebay, let me know.
Posted on Aug 28, 2009
BillB-SA
  • 2761 Answers
SOURCE: My sister has a Nikon Coolpix S220 and she dropped
Sorry, but there is no DIY fix for the lens problem, and any attempts at homebrew repair will likely worsen the problem. The camera needs professional repair, so I suggest that you take it to a camera shop (not the camera department at a large store) or contact Nikon customer service via the Nikon.com web site. Be sure to get a firm price before committing to repairs -- the cost to fix it may be close to the price of a new camera, and repairs typically only carry a 30-day warranty.
Posted on Dec 06, 2009
  • 11967 Answers
SOURCE: CAMERA SAYS LENS ERROR, HASNT BEEN DROPPED/ HIT,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 07, 2010
My sister's camera says lens error . she's gonna kill me if it's broken !!!!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 30, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Camera was dropped now it is saying that there is a lense error HELP!
My camera was dropped and now the lens will only detract half way. It says lens error and restart camera. It is a Cannon Power Shot SD1100 IS. Thanks.
Jul 13, 2009 | HP Photosmart M425 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 07, 2009 | Sanyo VPC-E760 Digital Camera
Broken lens : error
The lens unit will have to be replaced. This is a factory level service. It will most likely be more feasible to replace the camera!
Jerry G.
Apr 26, 2009 | Canon IXUS V2 Digital Camera
I can't turn my camera on????
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens error, restart your camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Jan 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
LENS ERROR 2 on my Casio Ex-V7
I read on the Casio website that this is due to an impact, meaning, the camera must have fallen or hit something really hard and strong.
Lens error 2 indicates that there is something wrong in the lens assembly. One possible damage concerns the image stabilization mechanism.
I also own a Casio EX-V7. My sister dropped it so hard that a dent has appeared on one of the front corners. Everytime I switch on the camera on record mode, LENS ERROR 2 appears for a few seconds.
Despite this, I can happily use the camera as usual. However, it's just annoying to see the Error.
I'm planning to bring it to a service center within a month from now.
May 26, 2008 | Casio Exilim EXZ75 Digital Camera
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
