Detergent is leaking from the bottom window of my ge profile front load washer
  • 714 Answers
You will have to replace the seal
Posted on Aug 21, 2010
Water is leaking from the bottom of washer what can be the problem?
Could be too much detergent. Always had the problem until I was told by repairman only cover the bottom of dispenser with detergent. Don't use the lines they come with. Only need a small amount. A large bottle should last months. Hope this helps.
Aug 04, 2014 | GE Energy Star WCVH6260F Front Load Washer
How to take the back off GE Profile washing machine
take off the bottom on the front, then pull the drum. cant take the back off.
Oct 08, 2012 | GE Profile WPRE6150K Top Load Washer
Ge profile front-load washer not draining
Firstly took the bottom front panel off and removed the drain plug/trap. Then the problem should be solved easily. For More information please visit Clothes Dryer Element .
Sep 22, 2012 | GE White Profile Series 15 Frontload...
Detergent is leaking on the top of the washer after done. When the washer is done with the load, it has detergent all over the inside of the lid.
Could be a number of reasons - the most common reasons are the door is not full shut or is faulty or the water pressure is too high. Also can happen if the machine is on uneven ground. If this is the case you can on most new machines adjust the feet.
Nov 01, 2009 | GE Profile WPRE6100G Top Load Washer
Water leaking out the bottom of door
You are using too much detergent. Make certain you use HE (high efficiency) detergent, and one of the service technicians suggests only using about one tablespoon of detergent per load.
Oct 18, 2008 | LG WM2277H Front Load Washer
GE profile washer
Thanks for the questionOn a ge washer theres a over flow tube located at the back left side Sometimes if you use a high sudzing detergent , it could leak not to much to worry about just change detergent to a low sudzing one THanks for the question The appliance doc
Sep 03, 2008 | GE WHRE5260E Top Load Washer
Washer leaks small amount. DIY fix: check hoses and ???
Wires found in hose!
When we turned washer on it's side, we found the hose from the pump to the basket had been pierced by two stiff curved wires, still embedded in the hose. Water was leaking around the wires. Wires had come out of an underwire bra! Dealer had only heard of this once before; on his own washer!
MORAL: handwash your bras, ladies.... or pull those wires out each time.
Apr 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
(front load ATF6000ES) is constantly leaking detergent
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
