Question about GE Washing Machines
Our washer will not work at all - GE Washing Machines
  • yadayada
    yadayada Aug 20, 2010
    model number and exactly what it is doing.
  • 92 Answers
Low water Pressure Don't Vote Only rate to max. thanx : )
Posted on Aug 20, 2010
I have a 2003 Envoy XL the rear windshield wiper works but the rear washer won't work
{: ) The rear washer pump is attached to the washer fluid reservoir. Below the left headlamp assembly. Ignition on, engine off. Switch ON the rear washer control. If you can hear the rear washer motor works, check for clogged hoses and tubes. If it's not clogged, your motor could only be running but not pumping.
If you cant hear the washer motor at work, its probably faulty.
To rule out if its a control switching issue, get a test light to check for voltage at the washer connector if you could only access it. Its better to check on that end. If you cant access it, at least probe the rear washer fuse at the underhood fuseblock. The test lamp should light everytime you switch on the rear washer switch.
Feb 03, 2011 | 2006 GMC Envoy
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Rear windshield washer motor works, but no fluid comes out
Rear washer may have it's own reservoir . Can you hear a pump humming when you activate the washer? Look in the under flooor compartment
Mar 22, 2009 | 1997 Chevrolet Suburban
1999 renault megane sport coupe
disconnect the washer bottle plug connector. then run alive and earth wire direct from battery to washer motor to see if motor works that way, if does then new need a new washer switch on the steering column. if not then replace washer motor. should work after that unless pipes blocked.
Jan 18, 2009 | 1986 Renault Sport
My 2006 Kia Spectra's windshield washer isn't working. When I pull the lever to start the washing I hear a couple of knocks to the passenger side dash area, but the washer doesnt work. I haven't seen any...
you know..i have a 2002 kia spectra and for the longest time i didn't have a washer cap on my windshield washer tube..i finaly found one in a junk yard and popped it on so i could have a windshield washer that actually works..and it still doesnt.
Sep 27, 2008 | 2003 Kia Spectra
Plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Jan 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer won't work... Period
the lid switch on the washer went bad. with out the lid switch working the washer cant do anything. its there as a safety to stop the washer when the lid is raise but when it goes bad it doesnt know if the lid is down or not so the washer wont come on
Nov 25, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
16 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
